matouse3
Very nice! Who came up with your tubing layout? Also, is it ok to just attach the tubing to the insulation like that? That really seems like the easiest way to go and then just use fibermesh concrete. Or did you lay the steel mesh on top of the tubing?
I designed the layout myself from research that I had done. I wanted a single zone for the floor, with the outer lines 6" from the wall, then continuing inward with 12" spacing. I also wanted the warmest water water going outside perimeter first, then working its way inside, then back to base. Blueridge will do a design for you, but they won't do something that complicated, so I was left to my own graph paper.
You will find several threads debating the "on the foam" vs. "in the middle of slab" with the pex question. I did my research and decided that for my application, stapling right to foam was the best bet. Its easy, it holds well, and (my greatest concern) it keeps the pex away from the control cuts when the slab is finished. Once the concrete starts pouring, the pex rises a little and your get concrete all the way around the pipe (from my experience) as long as you don't over staple.
I had the steel on top of the pex, on tables to keep a consistent height with the steel mesh and to also eliminate the risk of the concrete guys hitting my pex when they were trying to pull up the mesh.
