Hi All,
Over the winter I insulated my now-heated garage (24" OC trusses) with R19 fluff. I was able to hit most of the ceiling except for two areas around my lift (Atlas PVL-10). One is the lift bay... bottom of my joists are only 11'2" and so the lift at lowest height sits in between two joists as you can see in below pic (I realize I have to drop that bar as well if I want it to work as a shutoff
). The other is the light which sits inside the bay to stay clear of cars. There is storage space w/ a plywood floor up top but you can see there are gaps.
I rigged up some XPS to sit over the area... the one around the light is foamed in and sits a couple inches above the light.
I'm sure it's fine as is, but I'm debating running some radiant foil barrier the length of both open areas, tight to the foam/wood. I know it has very little insulating value but better than plywood, and it looks nicer than the current state too. I know RFB relies on an air gap but if I believe in my use case, the whole area from the floor to the foil is the air gap and at best it just bounces the heat downward, or at worst does nothing but looks better.
Anyone see any issues to this approach? Many thanks!
