Radiant heat air exchange.
Overhaulin63
Akron, Ohio
My existing garage has radiant heat, and I just built an addition attached to the outside of one of the structure's walls and wondered if I could simply exchange air (forced air) from the heated garage to the other? The boiler was over sized for the existing building and would easily be able to heat both if areas if it were an open structure.
Any thoughts or concerns?
jlv03
SE IA
Radiant floor heat? Or something else?
Is the addition a garage? Or living space?
American Locomotive
Rhode Island
Radiant heat works by warming the slab, which then warms the air and then everything else in the room. How big the is addition, and how open is it to the main space? It will likely heat just fine as long as it's not too big and wide open to the main area. Floor will be colder though.
O
Overhaulin63
Akron, Ohio
I was thinking along the same line with regarding radiant heating the air, but I was curious if anyone else had done it and what they experienced. The main space is insulated around the block foundation, walls, and ceiling so it doesn't have to work that hard to heat. The main is 32x60 and the addition is 32x32 (insulated walls and ceiling). I am just looking to knock the cold off of it during the Winter months and was just curious if anyone else here had tried the same.
