Ezzie
I am doing the plumbing to connect my hydronics boiler to the distribution manifolds for my in-floor radiant heating. I am a little confused about which side of the system the air seperator/microbubbler needs to go and the expansion tank location. The installation manual seems to contradict the installation notes that came with the Honeywell seperator I got. Maybe it doesn't matter but perhaps their is a radiant heating "pro" on here that could explain this a little clearer for me??
The boiler is a Triangle Tube Excellence which had an integral DWH tank. It has a built in Grundfos circulator pump that is on the "supply" side pushing the fluid through the floor. I am going with only this circulator and using zone valves on each of my 3 zone manifolds to control the flow. The manual says to install the air seperator/microbubbler in the supply line between the boiler and the supply manifolds. It shows the expansion tank and auto-fill on the return line between the return manifold and boiler. The instructions that came with the Honeywell air seperator/microbubbler show the expansion tank hanging off the bottom of it (there is a 1/2" NPT tap to allow this). Does it really matter which side of the floor the air seperator is on??
Any thoughts??
Any thoughts??
