redsand187
Something I've been thinking about.
I've got a steep driveway, that needs to be replaced next year. It's steep and not fun to clear when it snows.
I've seen some electric heat systems that is put in the concrete to melt tracks so you can still use your driveway. Seems kind of half *** to me, if I'm going to melt snow, I want to melt it all, not just a couple tracks. Unfortunately, these things are spendy.
So, radiant heat systems using water/glycol mixes seem to be all the rage for heating shops on this forum. Has anyone here done a system for outside?
I've got about 1000 square feet of driveway. Temperatures never get below the single digits, so I'd think a standard mix like 50/50 glycol would be plenty to keep the system from freezing up even if not on. An electric boiler/water heater, and pex looped through the slab seems pretty simple.
The real question I am wondering is how to calculate heat loss in a loop? The loops would need to be a minimum of 80ft long to go down and back up the driveway. So would say 10 degree slab temp be too much to overcome to raise up 40 degrees or so?
I'm thinking it may be possible to do a system like this for cheaper than the $8-10,000 an all electric system appears to cost.
So having a self clearing driveway would be nice.
