pamike
Getting ready to build a shop with radiant heat in the floor. Floor will be 5" thick. There appears to be two general methods of securing the Pex tubing.
-Method 1-Staple Pex to insulation
-Method 2-Tie Pex to wire mesh
Method 1 Pros-
-Keeps pex near bottom of floor so saw cuts or floor anchors are possible.
-Less risk of damage during pour
-Pex can be secured prior to messing with all the mesh
Method 1 Cons-
-Pex isn't completely surrounded by concrete so heat transfer may not be as good
Method 2 Pros
-Best heat transfer
-No special stable tool needed
Method 2 Cons
-Pex is at unknown height. No saw cuts or anchors possible.
-More risk of damage during pours??
Lets hear your opinions. I know a lot of people that have used method 1. I talked to a guy I know that has done a lot of radiant heat. They use method 2 and shamed method 1, but then again all they use under the slab is bubble wrap...
Method 1 Pros-
Method 1 Cons-
Method 2 Pros
-Best heat transfer
Method 2 Cons
