Radiant heat install
JECulver
I am starting my radiant heat install in a Barndominium. I'm in central Montana and my first question is about vapor barrier under the insulation board under the concrete. Is it necessary? We live in a very dry climate so I'm thinking it will not be needed. What are your thoughts.
Thanks John
road_king
Eastern USA
We put a vapor barrier down under the 2"foam. Some say put it on top of the foam. Either way, best to use a vapor barrier.
purediesel
Ada Oh
What's a few hundred dollars for the piece of mind that there is no chance to get moisture into your slab and into your house?? I would be using a Class A vapor barrier if it was my house and not some cheap poly. My 50x80 was around $6-700 with the proper vapor tape.
Firebrick43
West central Indiana
Put it down, it might help keep issues from happening in a wet year and it helps keep the concrete moist so the ground doesn't **** the moisture out and stop the curing chemical reaction which will result in lower strength of the concrete.
I suggest stegowrap. It goes on top of the foam.
