So I fired up my heating system yesterday and I think I got some bad advise from the local heating supply store. I haven't went out and checked this morning, but I don't think I have enough water volume and now I could really use some guidance as I'm afraid I'll be freezing the slab and I think my problem is affecting my house system.
Here is the setup.
Outdoor wood boiler with two Bell and Gousett NRF-22 pumps located on the boiler independently controlled.
1 pump runs to the house about 100' through 1" pex into a water to water exchanger and back to the stove. Never had an issue with this setup for about 7 years. This is a constant pump circulation setup.
The other pump was purchased when the stove was new for an additional pole barn. The barn setup is as follows. 1" pex about 100' to the pole barn hooked directly to a 6 zone manifold each run is about 240' of 1/2" pex then returned back to the outdoor wood stove.
Both pumps share a return at the wood stove.
I don't have confidence that I'm getting proper flow back to the stove and it seems to be affecting the house loop. I believe that I need to put a pump in the pole barn. The real problem I have is I don't know if I should upgrade the pump on the stove and add a pump on the return side after the manifold.
I'm hoping there are some pumping guys on here that can lead me in the right direction.
Oh, the pole barn pump is being controlled with a pump controller off a thermostat. I ran 110 from the barn back to the wood stove when buying the pex.
Sent from my iPad using Tapatalk HD
Here is the setup.
