radiant heat, what about the edges?
unknown_element
Im building a 32x48 pole barn and have been researching radiant heat. Heres my question, you have 5-6" of stone,2" foam, pex, then "in my case" 5" concrete, do you insulate the sides of the concrete? If so, how?? Thanks for your time.
csp
Franktown, CO
Monolithic slab that the walls are built directly on or is there a separate stem wall surrounding the slab?
BLUBAYOU
FPSF (frost protected slab/shallow foundation). In a nutshell, foam insulation down from the slab, then out from the slab horizontally, like so:
Looked into it for my build, but decided against radiant since I won't be spending long days in the garage. I used radiant in my house and love it, but in the garage it was unnecessary for my intermittent use needs.
More info:
http://www.toolbase.org/pdf/techinv/fpsf_techspec.pdf
csp
Franktown, CO
Doh! I missed the pole barn part in the original post. You'll just have a floating slab, which you insulate around the perimeter of it with foam.
Highbeam
Mt Rainier foothills, WA
Your form boards around the edge. Attach 2" foam to the form boards. Some folks extend this vertical foam to the frost line but definitely put it on the full height of the slab.
See the pink foam in my pics? Also, you really really should put in a VB between the gravel and the foam. It's cheap and will help prevent moisture from the earth from soaking into and through your slab.
maxspeed96ct
Have any other pics highbeam ?
What about on a normal foundation? what do you put around the permeter ?
U
unknown_element
did you buy the 2"X2'X8 foam and trenched it beside the slab? thanks for the picture's that really helps, any more?
Highbeam
Dave went deep, I stayed shallow since we don't have frost and I didn't want to dig out my compacted subgrade. Deeper with the foam can only improve system performance though.
I don't have many more pictures to show the foam.
BadgerBoilerMN
Minneapolis
I does not matter if the insulation goes out or down or in. The Swedes insulate the foundation wall's outer edge and follow the slab in. All concrete inside of XPS. Unless you need a foundation for some inner wall support, you will not need a FPSF.
You will need to cap the outer edge of the concrete slab, since this is a radiator and will have elevated temperatures.
Bigturk
Here is a pic of what I did for my slab. I left pressure treated plywood around outside edge to protect foam.
U
unknown_element
Im ready to put my foam in, and um unclear how to stop the foam on the sides. I have a 2x12 bottom board, do you go all the way to the top where the top if the concrete should be or stop short?
matouse3
Mid-Michigan
There are a few options with this, I was also unsure what to do. I cut mine at a 45 angle so that no foam was showing, but I had some coverage all the way to the top. This also gave some strength to the edge and didn't leave it only .5 inch thick for 2 inches along the edge or something like that. Others on here have it go all the way to the top and just cover it with something like a vinyl trim piece.
There are some photos on my build thread:
http://www.garagejournal.com/forum/showthread.php?t=152392
Not a close-up photo, but you can see it in the photo with the manifold.
I glued it to the block and the bottom layer, but if I had to do it over again, I would have run it lower to help hold it in better. The glue worked, but I didn't have as much time as I wanted to let it set up. If I had just run it the 2 inches deeper to line up with the bottom layer of foam, I think it would have held better. It didn't float or anything, but it made me nervous. The concrete guys knew what they were doing and held it in place as the concrete came off the truck and after that it was locked into place by the weight.
burleyfarm
Northern Michigan
We just completed two buildings with in-floor radiant heat. One a 6000 sq ft garage. We installed 2 inch foam from the top of the slab to the bottom of the footing. There is a lot of heat transfer from an uninsulated slab and footing. Where necessary we flashed any exposed styrofoam to protect it from the sun.
I have a friend that put 2 inches under his radiant heated floor but failed to put it along his footing. He's now getting ready to dig up his foundation and install 2 inches on the outside of the foundation. Lots of work.
U
unknown_element
here's my garage, 5" of bermstone coming by friday, then putting the foam on top. how to do the sides? im still lost.
yankeze1
Here you can see all stages of my floor, as I was able to complete some of the work towards the back while waiting on concrete guy to come dig the trench drain.
Along the far wall you can see the upright foam board, from the top of the batter board to 2' deep (split full 4x8 sheets), between posts on the inside. Rest is compacted gravel, vapor barrier, 2" foam board, pex and concrete.
Hope the picture helps.
Good Luck!
