Gunslinger99
- Joined
- Feb 13, 2010
- Messages
- 50
I just got done installing the radiant tubing before they pour the concrete slab and am doing the pressure check now. I have been searching this site and other sites but I can't quite seem to find an answer for my situation. I'm hoping someone can help me out here...
I put about 80 psi of air in the lines yesterday afternoon (inspector wants 100psi but I didn't have an air compressor on hand at that time, used a tank), ambient temp gauge in my truck said about 87. Went back to check on it after dark and the ambient temp had dropped down to around 50 degrees and the pressure gauge on the PEX lines said about 60 psi. I put about 10 psi back in. I checked the pressure gauge this morning and it was down to 20 psi and the ambient temp was about 30 degrees. I didn't pay much attention to the temperature as I wasn't really sure that it mattered that much at the time.....
Not knowing much about this kind of stuff, from what I have read it appears that changes in ambient temperature will affect the pressure in the tubing. If this is correct, then is the pressure change that I am experiencing normal? Seems like if there was a leak I would not have any pressure left in the lines this morning, right???
Thanks in advance for any help with this.
