Husky79
Hello everyone, I took a day to research on a DIY method of making my own heating and zone control panel and how much that would compare to a ready to install system like Menards offers.
Ready system with heating, 2 zone control panel, 115k BTU condensing boiler with 4 port and 6 port manifolds would run me $6,420 before taxes and rebates.
DIY system would cost me $3,239 before taxes and rebates. That's a big saving doing it myself. I am doing it myself, yes all fittings are sweat not push fit. Changing fittings to push fit like SharkBite would raise the price.
I have provided a spreadsheet for the parts needed. If anyone knows where to get any items cheaper, please let me know and I can update the spreadsheet. Also if I'm forgetting anything let me know too.
| DIY parts list for control and zone panel for Hydroponic Radiant heating in 40'x48' slab, 3,000 linear feet of pex, 2 zones, 10 branches total | |||||||
| Item | Price each | Quanity | Total | Seller | Link | Stock # | 12% Rebate |
| 1" Threaded Y-Strainer, Lead-Free Brass | $15.95 | 1 | $15.95 | Pexuniverse.com | https://www.pexuniverse.com/1-threaded-y-strainer-lead-free | YST100-LF | |
| Watts® 4.5 Gallon Potable Water Expansion Tank | $49.96 | 1 | $49.96 | Menards | https://www.menards.com/main/plumbi...ion-tank/det-12-m1/p-1554359169622-c-8691.htm | 6831773 | $6.00 |
| 3/4" F30 Pressure Only Safety Relief Valve (30 PSI) | $15.55 | 1 | $15.55 | Supplyhouse.com | https://www.supplyhouse.com/Cash-Acme-20166-0030-3-4-F30-Pressure-Only-Safety-Relief-Valve-30-PSI | 20166-0030 | |
| 1" SWT Isolator Flange Valve w/ Pump Gasket & T-Handle | $27.95 | 4 | $111.80 | Pexuniverse.com | https://www.pexuniverse.com/1-sweat-circulator-pump-flange-valve | FVC2-100 | |
| 1" Sweat Isolator Flange with Drain | $30.02 | 2 | $60.04 | Supplyhouse.com | https://www.supplyhouse.com/Bluefin-IFDS100-1-Sweat-Isolator-Flange-with-Drain | IFDS100 | |
| 1" Sweat, Spirovent Jr Air Eliminator | $98.95 | 1 | $98.95 | Pexuniverse.com | https://www.pexuniverse.com/spirotherm-vjs100-spirovent-1-air-eliminator | VJS100 | |
| 1" x 1" Pro-Pal Full Port Brass Ball Valve w/ Reversible Handle, Primary/Secondary Loop Purge Tee | $75.72 | 1 | $75.72 | Supplyhouse.com | https://www.supplyhouse.com/Webston...sible-Handle-Primary-Secondary-Loop-Purge-Tee | 58644 | |
| Grundfos 1/25 HP Cast Iron Circulator Pump | $135.99 | 3 | $407.97 | Menards | https://www.menards.com/main/plumbi...or-pump/ups15-58fc/p-1444433736251-c-8523.htm | 6655405 | $48.96 |
| 1" Sweat (Solder) Brass Ball Valve, Full Port | $9.85 | 3 | $29.55 | Pexuniverse.com | https://www.pexuniverse.com/1-sweat-solder-brass-ball-valve | BV100S | |
| Taco 4 Zone Switching Relay | $169.99 | 1 | $169.99 | Menards | https://www.menards.com/main/plumbi...ing-relay/zvc404-4/p-1444433733024-c-8523.htm | 6655609 | $20.40 |
| 2.5" Tridicator, 3-3/8" Well, Back Mount Temperature & Pressure Gauge (0-75 PSI, 30 to 250-Degree (F)) | $14.36 | 2 | $28.72 | Supplyhouse.com | https://www.supplyhouse.com/Bluefin...re-Pressure-Gauge-0-75-PSI-30-to-250-Degree-F | TDB25-75-BKX | |
| Total | $1,064.20 | $75.35 | |||||
| Fittings | Price each | Quanity | Total | Seller | Link | Stock # | |
| (Contractor pack of 10) 1" 90 Degree sweat elbows | $26.69 | 2 | $53.38 | Menards | https://www.menards.com/main/plumbi...gree-elbow/w01490j/p-1505802450565-c-8565.htm | 6871935 | $6.41 |
| NIBCO® 1" FTG x Sweat Lead-Free Copper 90-Degree Close Rough Elbow | $5.09 | 3 | $15.27 | Menards | https://www.menards.com/main/plumbi...reet-elbow/w01570d/p-1444449323960-c-8565.htm | 6871408 | $1.83 |
| NIBCO® 1/2" Sweat x FIP Bronze 90-Degree Elbow | $4.39 | 1 | $4.39 | Menards | https://www.menards.com/main/plumbi...gree-elbow/c00090c/p-1444449111610-c-8565.htm | 6872957 | $0.53 |
| NIBCO® 1/2" Copper 90 Degree Street Elbow | $0.94 | 3 | $2.82 | Menards | https://www.menards.com/main/plumbi...reet-elbow/w01550d/p-1444449343823-c-8565.htm | 6871385 | $0.34 |
| NIBCO® 1" Sweat x FIP Lead-Free Copper Adapter | $6.99 | 4 | $27.96 | Menards | https://www.menards.com/main/plumbi...er-adapter/w01100d/p-1444449332144-c-8565.htm | 6871961 | $3.36 |
| Watts® AquaLock™ 1" Push to Connect x MIP Lead-Free Brass Adapter | $11.99 | 8 | $95.92 | Menards | https://www.menards.com/main/plumbi...s-adapter/0472015/p-1444446170104-c-12709.htm | 6809738 | $11.51 |
| Watts® AquaLock™ 1/2" Push to Connect x MIP Lead-Free Brass Adapter | $7.57 | 1 | $7.57 | Menards | https://www.menards.com/main/plumbi...s-adapter/0472011/p-1444446199389-c-12709.htm | 6809702 | $0.91 |
| NIBCO® 1" Sweat Lead-Free Copper Tee | $7.99 | 2 | $15.98 | Menards | https://www.menards.com/main/plumbi...-sweat-tee/w01720d/p-1444449336060-c-8565.htm | 6871945 | $1.92 |
| 1" x 3/4" x 1" C x F x C Cast Brass Tee | $17.32 | 1 | $17.32 | Supplyhouse.com | https://www.supplyhouse.com/Everflow-CFCT1341-NL-1-x-3-4-x-1-C-x-F-x-C-Cast-Brass-Tee-Lead-Free | CFCT1341-NL | |
| 1" x 1" x 1/2" CxCxC Reducing Tee | $8.36 | 2 | $16.72 | Supplyhouse.com | https://www.supplyhouse.com/Elkhart-32828-1-x-1-x-1-2-CxCxC-Reducing-Tee | 32828 | |
| Oatey® 1" Epoxy-Coated Split Ring Pipe Hanger | $1.89 | 50 | $94.50 | Menards | https://www.menards.com/main/plumbi...e-hanger/336025/p-6698461259109666-c-9424.htm | 6934471 | $11.34 |
| Oatey® 3/8" Top Plate Connector - 5 pk | $6.99 | 10 | $69.90 | Menards | https://www.menards.com/main/plumbi...onnector/335607/p-6698461259109939-c-9424.htm | 6934568 | $8.39 |
| Hillman® 3/8"-16 x 72" Zinc Threaded Rod | $6.49 | 1 | $6.49 | Menards | https://www.menards.com/main/hardwa...threaded-rod/11019/p-1444432412725-c-8724.htm | 2279211 | $0.78 |
| Total | $428.22 | $47.30 | |||||
| Manifold | Price each | Quanity | Total | Seller | Link | Stock # | |
| 4-branch Stainless Steel Radiant Heat Manifold Set w/ 1/2" PEX adapters | $195.95 | 1 | $195.95 | Pexuniverse.com | https://www.pexuniverse.com/ssm204-steel-radiant-heat-manifold | SSM204 | |
| 6-branch Stainless Steel Radiant Heat Manifold Set w/ 1/2" PEX adapters | $250.95 | 1 | $250.95 | Pexuniverse.com | https://www.pexuniverse.com/ssm206-steel-radiant-heat-manifold | SSM206 | |
| Total | $446.90 | ||||||
| Boiler | Price each | Quanity | Total | Seller | Link | Stock # | |
| Hydro Smart 115 PLUS NG/LP Microboiler | $1,299.99 | 1 | $1,299.99 | Menards | https://www.menards.com/main/plumbi...oiler/hs115plus/p-3289655538129430-c-8519.htm | 6651012 | $156.00 |
| Total | $1,299.99 | $156.00 | |||||
| Grand Total | $3,239.31 | $278.65 |
