slackdaddy1
Finally getting ready to finish my slab heat in time for winter and have a few questions.
22x32 garage, 1" blue board under 4" slab, R19 walls, R40 ceilings, premium insulated doors ( 2- 8'H x 10'W)
2 - 300' 1/2" pex loops.
It will be a closed system with no connection to domestic water.
EMB-S-5 electric boiler.
I do want to run antifreeze, can Propylene glycol RV antifreeve be used?
Does a closed system run under pressure? if so what pressure range is desired and how to achieve?
A 4.4 gal bladder tank is being used, I assume the only way it will do any good is if the system is under pressure to push the bladder down?
Should the Elec boiler be mount below all the other components so as to not allow it to run "dry", I see most of the elec boilers mounted on the wall above everything else.
Has anyone added a low water cut off? is it needed, or do new boilers have this built in?
Thanks,
Slack
Thanks,
Slack
