d_douce36
Hey Guys,
So just got my hydro bill after running my new radiant system in the garage for the first time, which was 2000Kwh higher then normal. The Garage is 28x32 with 10' walls and a 12x32' attic space in the 8/12 trusses. So all together 1280sqft of heated space. Walls are 2x6 with R22 roxul, ceiling with no living area above are R40+ and attic portion knee walls are R30 with the ceiling R22. The slab uses 2" Halo Subterra XPS graphite infused insulation across the whole slab. 2 foot Frost wings were also installed. Whole building is well sealed with 10 mill poly. Two 8x9 Cloplay R18 over head doors on the main floor. The attic space aboce has two 48"x64" triple pane low-e windows. The hydronic set up is a 9kw Thermolec utilizing 4 loops of 1/2" pex average runs about 200' at 14" spacing. The building is drawing around 66Kwh Per day at indoor temp of 14c or 57F with an average temp of -4c or 24.8F. Im in Manitoba, Canada and we will see temps down to -22F or -30c so the system hasn't really been tested. Boiler has supply temp of 120F with a flow rate of .3 Gpm on the 4 loops
My question to you guys is why is it costing me so much to run? What am i missing? Any suggestions
