Testocules
- Joined
- Aug 17, 2016
- Messages
- 4
Hello All,
Hopefully I have the right forum here - could be heating/AC or could be flooring.
A 'pre-slab-pour' question on how to finish insulate/isolate the perimeter foundation walls of my small radiant garage floor...
Scenario...
-garage is part of house - attached on 1 side wall and also the back wall, other side wall is the end of the house, and the front wall is obviously fronting to the exterior as well.
-garage is only 12' wide X 18' long (wish I had more!)
-floor will be heated by a single zone pex run.
-floor will have a recessed 'pit' in the center that will house a 7' X 2' motorcycle lift.
-floor will reinforced with rebar 12" on square grid pattern (pit will be reinforced with rebar tied to floor rebar).
-concrete will be 5.5" thick for pit pad and 5" - 6" thick for the balance of the floor.
-concrete will be 4500 psi with fiber, appropriate slump.
-base is well compacted sand/gravel (it's been there for years and I've plate tamped it even more for extra measure).
-under slab from base up will be 6" of 3/4" crushed stone (compacted), 10 mil vapor barrier (tape sealed), 2" eps rigid 250 foam, rebar on chairs to center the reinforcement to the middle of the slab.
-pex will be tied to rebar on 8" centers (also centered mid-slab).
-the garage has 2 foundation walls exposed to the exterior and 2 foundation walls that are separation walls between heated interior basement spaces.
-2 exterior walls will be insulated to a depth of 4' below the slab with 2" eps rigid foam.
-2 interior walls are against heated basement space so will not be insulated.
-I'm in Southern Ontario, Canada, where we see winters similar to upper New York and Michigan (hence the radiant!).
Question...
For the perimeter walls, I realize it's beneficial to insulate the perimeter walls (particularly those exposed to the exterior) to create a thermal break and reduce heat transfer from the slab to the foundation walls. I also realize that there may be a need for an isolation joint around the perimeter of the slab to allow for expansion/contraction (maybe?). I'm uncertain whether I need both for my size of slab and conditions, or if I'm fine with just insulation beveled to the top of the slab, or if I should stop the insulation at the bottom of the slab and put 6" or so of isolation board on top of the insulation board where the slab would otherwise meet the foundation wall.
I've read that some people 45 degree bevel the top of the eps against the foundation wall and pour to the top of the bevel to minimize the amount of exposed foam around the perimeter of the slab. Some stop the foundation wall eps at the bottom of the slab then put 1/2" isolation board from there up to isolate the slab from the foundation wall (may also act as a bit of an insulator?)
I can easily put isolation board on the 2 interior walls as they won't be insulated...does this act as enough expansion/contraction isolation for the whole pad and size of the pad?
What might you recommend I do around my 2 exterior walls?...beveled eps only, eps and isolation board together, or isolation board only sitting on the top edge of eps?
Sorry for the long read, just want to paint the clearest picture I can - hope I did but can certainly answer any questions
Thanks for suggestions based on your own expertise, experience and/or learnings.
Scenario...
Question...
