formula388
I am planning on setting up my in slab radiant heat and have some questions prior to purchasing parts.
Is there an advantage of slab sensor vs thermostat air temperature regulating for my application?
What is an Outdoor Reset? From what I understand "IT" (not sure what it is) takes into account the outdoor temp? I've heard for small shops this might not be a big deal? My shop is very well insulated.
If the electric boiler is modulating, can I "oversize" it? I would like to stay on a reasonable budget but the cost difference from 3kw to 6kw seems minimal with most brands.
What size boiler do I need? I have spoken to several companies that sell prebuilt kits and have gotten estimates from 2kw to 5kw.
Background Info: Designed and used as a small personal auto shop. I have a two post lift and automotive tools in there. When I work in there I might open the door 4-5 times a day. Then I might go several days without opening the door at all. I poured my slab about 3.5 years ago with Oxygen Barrier Pex about 2" from the bottom of the 6" slab. Under and around the slab is 2" XPS foam. The building itself is about 500SF (21'x23.5') with 12ft ceiling. It is fully spray foamed with closed cell. Only window is a small one in the man door. The 9' x8' garage door is well insulated (Claims R19) . I have about 500 feet (1 loop of 240ft, another loop of about 270ft) of 1/2 Oxygen Barrier pex. I have a manifold already and the pex has been pressurized and holding pressure for the past 3.5 years.
My only reasonable fuel source for the boiler at this time is electric. I have more then sufficient room in the panel for this.
I have a mini split that can comfortably heat the space, but I was looking forward to a "warm floor."
I did not put a slab sensor in when I poured the slab. I didn't know much at the time. I don't mind drilling, once I can get some heat in the floor to verify where the tubes are using FLIR Thermal imaging camera.
I know this was a long winded post. I appreciate the insight.
Thank you,
Dennis
Thank you,
Dennis
