MerlinsBeard
I have some rafters that are 16" spaced, but some rafter bays are a little on the skinny side (around 12" in the sides of the dormer section of the ceiling).
I'm using ADO Provent 4' x 16" since that was what I could find locally. Because of the X protrusions, Just cutting it in half and overlapping the two sides doesn't look like it would be very form fitting.
Cutting from one end means I'd have to force a new crease to try to fit the shape.
If I have to make a new crease, I might as well try to add a "V" in the middle so that instead the baffle profile looks like
_________ __________
___/ \_/ \___
Since I'm adding the vertical pinch, it would effectively reduce the width and hopefully not horribly disfigure the baffle plastic. I'm thinking of setting up some kind of jig and using a heat gun to try to force the rafter baffle into the profile.
Thoughts? Is this a reasonable idea, or maybe a better alternative?
___/ \_/ \___
