Rage 2 Dry Cut Chop Saw $199 @ Menards!
ScubaSteve
New Bern, NC
Oh yeah...you get 11% back in rebates too....so that brings the saw to $178...at that price, no need to look at the Rage 4 (which I almost bought because it is $149).
PT Doc
What would you be cutting with the enclosed 36 tooth blade besides solid stock of probably 3/4" thickness to allow for 3 teeth in material?
ScubaSteve
New Bern, NC
For me it'll be mostly square tube for projects like tables, racks, etc. But it's good to have for solid stock, etc. Apparently these do a pretty decent job for quite a long time if you don't manhandle them. I don't do production stuff, etc. so I'm happy.
JP.
Menard's also has the Rage3 10" sliding miter saw for $149 ($100 off) this week.
Yes the Rage3 has a 1" arbor, so blade options are limited. Oshlun makes one for ferrous metal, and Evolotion has the multi-purpose blade, a ferrous blade, and a wood blade.
JP
Gore
NorCal
I may order one of the sliding miter saws and have it shipped to CA. It would only be 179 which still sounds cheap. I already have a 10" slider so I'm not worried about the lack of blades as I only want this to cut metal with. My questions are: Does this saw go on sale often? Does it come with a blade that I can use for steel? Is there anywhere closer to CA that I should look before buying this?
Twitchr
The blade it comes with does cut steel, but they also sell one specifically for steel. From the reviews I read its not worth it. Cheap base, angle guide is wrong, and replacement blades are around a hundred dollars. I seriously contemplated it before I saw the price of the blades. I think I will just get a normal chop saw, and replace the blades a little more often. Check amazon for some insightful reviews.
Gore
NorCal
Seems like they're pretty hit and miss...but when they miss they miss BADLY
There are a ton of good reviews out there as well though.
