Vicious Customs
- Joined
- Jan 3, 2012
- Messages
- 66
Okay, I need a reality check. I've been debating some options for updating the flooring in my pole barn, and I'm looking for opinions.
To start, I was fine with my dirt floor for quite some time, but I've got issues with mice and rabbits digging under the walls and coming up through the floors, and it's starting to bug me. It's more that dirt is getting under my sliding door, and that it's now much looser that it was than anything.
I think I've settled on a solution that won't break the bank, can be done over time, and should hold up to the use I'll put it through, but am always open to constructive criticism. I am under the impression that I can start at one end of the barn, dig down to the appropriate depth, and inlay railroad ties, staked throughout. This will allow me to do sections at a time as funds are available, give me some instant gratification, they are readily available, and it's something I can do myself. I also believe that I they are durable, and will hold up for some time. Considering that I don't have any underground wiring, or plumbing, I don't see an issue there. Lastly, I think it would look really cool once completed.
So, I'm open to thoughts on the matter, and any suggestions as to alternatives. I've given up on my caliche and soil cement options. It appears as though they won't hold up over time.
, how about doing some mitigation work along the outside wall first? What I suggest is that you do some 'Irish Engineer Work' with a pick and shovel along the outside wall of your pole barn. A ditch 10"-14" deep, fasten the short lengths your wall material (if metal siding or galvanized tin sheet if siding is wood) to your existing walls, back-fill with drain tile and gravel, and you've created a solid barrier against tunneling trespassers! Your building stays free of ground water, you've put in a barrier against the most persistent diggers, and now you can build your floor with whatever, whenever you get the time and money. Lot's of sweat equity up front with not too much cost and it solves your critter invasion problem right away. For your entry area, you can hand pour a threshold/apron with re-bar extensions for future piecemeal expansion. The buried metal siding/galvanized tin provides a form for future inside flooring material.
, but it's getting broken up, and I really like the idea of something I can sweep and keep relatively clean.
