kwoody51
Been getting lots of rain here lately... and discovered my vertical vent pipe for my heater in the garage is leaking/ dripping. Water appears to dripping along the outer pipe. I suspect the caulking on the roof collar gave up the ghost and allowed for water to dribble down the pipe into the house ... what say you all?
We've been in the house ~3 years and this is the 1st time it's done this... making me think it's the exposed sealant.
I tried to caulk it in the rain but don't think it really held so will go back after it's dry and use some Vulkem sealant.
Appreciate any thoughts! Kind freaking out as I'm not wanting this leak to turn into a bigger water damage problem...
Here's some pics.
It's dripping along the outer pipe. If you look really close you can see one drip ready to drop at the 6 o'clock position. You can also see a faint outline on the drywall, behind the drywall is the flange of the 'outer insulated pipe' the pipe in the house slips into since it's through the roof.
So it appears some water dribbles onto the pipe and other water is redirected around the flange to the drywall... which would also explain the photo of the wet foundation wall.
Wet foundation wall, this is directly 'in line' with where the vent pipe is. Suggesting that some of the water is finding it's way to the wall and thus trying to exit the bottom.
Here's the view on the roof
The area I suspect it's leaking from and what I tried to re-caulk... clearly not awesome job but on top of the ladder while raining I was going for function, not form.
I thought 'maybe' it could be leaking at this position as well but not sure where the collar meets the flat part.
Here's some pics.
