Rain water pump question
Jack 07
Mid-Michigan
My game plan is to set up a rain water tank and use a pump to wash cars etc. (So far not illegal to do here). My question is, what type of pump? I want it to come on when the hose is open and off when not. Is that an "on demand" pump? Or can I have a pump run when the hose is closed? Anyone do something like this and can provide some guidance?
reasoning is we have very hard water and very nice cars.
1953mercury
Steamboat Springs CO
You just need a standard pressure switch on the outlet side of the pump. Available at the hardware store or plumbing supply. A pressure tank would keep your pump from running constantly. Mike
Nowater
Southwest Florida
That's a lot to do to wash your own cars. Are you washing someone else's? If so there may be requirements as to what are you planning to do with the runoff from washing the cars. Check first.
J
Jack 07
Mid-Michigan
Nope just washing mine, but I do it a lot. And in looking at the propane tank where the sprinklers hit it, it is brown with rust. Don't want that on the cars. There is a osmosis system you can buy, but that is $$$.
HeelSpur
WV
You probably want something like this for just washing cars.
th
Bear
Salem, Oregon
Or if you have a 12 power supply (think car battery) you could just use an RV water pump. Light, reasonable cost & on demand.
HOTFR8
Castlemaine, Victoria. The Hot Rod Centre of Austr
Take into consideration if you intend to run a pressure washer. I have a small electric pump and just plug it into a power point as I use it. I have snap on hose fittings on each end bigger fitting on the inlet so as not to get confused. Turn on the water and turn on the pump (never let it run dry) and away you go.
I have a rain water tank here just for the purpose of vehicle washing as it is much better than the town water.
If you use it carefully you do not need a pressure switch like the one in the photo. If you intend to make it a permanent fitting and plumb it then use a pressure switch.
