Raised ceiling
dak911
S FL
I am going to install a lift in a 9' ceiling height garage...there is attic space above.
I want to make an 2' area of space about 5' wide by 10' long.
This means cutting the joists (joists run across)...how do I retain the structure in that area?
heffneil
Naples FL
I am not a fan of paying consultants or engineers. I always feel like you pay too much and get a bunch of information thats pretty basic and logical.
In this case though I think if you care about the integrity of your garage and or home you should have someone evaluate this. I have seen trusses that have a flat peak on the inside but theres a lot pre-engineered. A retroactive re-configuration would take some loading calculations...
Good luck and let us know what you find!
D
dak911
S FL
I think I'll need to remove the drywall in the area to see what is there, then I can get a better idea....
pbon
You need to understand the construction of the building. I just did a cutout for a lift in my garage. I have a full 2nd floor above and an attic above that. The construction is balloon frame, so integrity was not conditioned upon the 2nd floor remaining intact. If you have a typical modern garage with sill plates on a concrete foundation, 2x4 studs on the sill plate going up to another sill plate at the attic level, and a standard pitched roof, the attic floor joists you want to cut are structural.
You may be able to install collar ties 2 feet up into the attic ceiling, tying the ceiling rafters together to compensate for some of the loss. You would then box in your opening so the joists come up to opposite sides of the box and can push or pull on the box for structural support. A stairwell from one floor to another requires a boxed opening like this in the floor above but is usually a little smaller than the opening you want.
Hopefully there are some builders in here who can give more professional input.
kbs2244
Collar ties, if they apply, are the answer.
Do some research.
