Raised floor
jksmith
Indianapolis, In
anyone have a raised for in there garage or a THICK tile?
Basically looking for input on putting a 1 5/8 thick brick down as my flooring but dont know how thats going to do with my getting in and out of the garage,
since i have a blacktop drive i can always build up the asphalt to level it out ??
Any opinions?
rieferman
I think brick flooring will be a pain in the **** in a garage. It will trap dirt and be difficult to sweep. The cracks could be annoying for rolling items across (such as cart w/ casters). I'd use those bricks as a wall treatment someplace.
mackrmnn
Midlothian, VA
I think the biggest problem you will have is adjusting your door. You might not be able to get the gap out, at the top, without raising your door tracks.
J
jksmith
Indianapolis, In
didn't think about that! was just thinking looks and price (well for me i can get the CHEAP)
i should be able to raise everything 2" and it shouldn't be a problem, and actually help me out a little with my height problems while the door is open
planning on getting new door and hardware
back2class
That would make a horrid work surface and a ***** to keep clean, cost money, take time and otherwise about the worst idea I have have herd here in several weeks.
kenfath
Upland, CA
Had a friend who installed the 12-foot wide brick pattern sheet flooring in their garage. It really looked sharp! They parked two cars on it regularly and did some woodworking. They would also use the space as a family room. When I last saw it it had been down for about four years and still looked good.
J
jksmith
Indianapolis, In
don't understand how its hard to keep brick clean??
it will be cheaper than any other method for ME other than maybe a DIY epoxy and wouldn't take but maybe a weekends worth of work
back2class
Have you tried to wipe oil or paint off brick??? Nevermind the dirt that will build up in the low spots between the pattern.
J
jksmith
Indianapolis, In
a sealed brick wouldnt be much different than concrete
the pavers i would be using shouldnt be any low spots, the are squared edge 4x8 pavers
