Ramp Joint Puzzle
tearapin
The attached picture is of a ramp I want to build. Actually they are side ramps for a motorcycle lift. I need to make the downhill transition at the joint the red line marks.
I know I can likely cut a notch or angle in the wood. But that is likely to weaken the joint. My bike weighs 700 pounds and if I am on my way up the ramp and have to plant my foot at the joint a fear a failure. Ramp will be 2x8's on the top. Support board will be 3.5 inches wide (2x4's) so pic is not to scale.
Any suggestions as to how to make this angle transition?
HoosierMark
Southeast IN
If you were building a house and putting a rafter board that would be called a birds mouth cut. Google birdsmouth rafter cut.
rust in the eye
Chicagoland
If you don't wish to weaken the ramp board with a birdsmouth cut you could make a vertical cut on the end of ramp board(like a ridge cut) to but against the horizontal board then make an angle cut to the supporting board to correspond to the ramp angle.
If you just cut a plumb line down where your red line is, you will still have a hump. If you cut your bird mouth there, will that be weaker than cutting a notch in the on-edge board that the ramp is resting on? I Dunno?
Just asking, but I think notching the on-edge board might make more sense as far as "least reduces strength."
PCustoms
VT
With no real scale to that drawing or knowledge of your tools I would hesitantly suggest beveling the horizontal piece. If you want it super tight cut a matching bevel to the ramp.
Wood would not be my first choice for a rampnon a lift though
Al G
Arizona
Is something preventing you from using 2 support boards? You could have solid support under each ramp board. Clamp them together so nothing moves.
tarbellb
Oregon
Just add a cleat (green) to the front of your vertical support for the angled board
If you are concerned about the shear load, gusset (yellow) w plywood or double up verts
It's a 2x wood ramp, don't over think it
T
tearapin
I was planning on using pins to hold it together for ease of disassembly and storage.
Firebrick43
West central Indiana
T
tearapin
Not really sure what he did to make the joint transition here, Are you?
Firebrick43
I thought of that but my ramps won't be that long and the brackets would need to be bent. Not sure that is possible.
Your ramps are not going to be that long but they are also not going to be sitting pickup bed height either so the angle should be the same.
And if the angle is shallower than the typical ramp it will be ok. Steeper would be the problem.
They also make steel ones that can be bent to the desired angle if you want easily
