I inherited an older German made Ramset model 340 hammer drill. I've not been able to find a manual or much of anything else about it online.
I bought some SDS plus bits and was hoping they would work with it. They slide in perfectly, but do not lock in. I checked out the bore of the chuck and there is a key for one of the slots to go onto, but the retention ball is located opposite of the key, so it is 90 deg off of where it should be if it were an SDS tool. I could drill using these bits, but getting the bit back out of concrete would be a bit of a PITA.
Does anyone know what bits are to be used for this? If I knew, I could look for an adapter for that to SDS plus.
Worse comes to worst, I could weld up the end of one of the slots of the bits I got, but I don't want to go there yet.
EDIT: corrected wrong model number
