Mike F
Okay, so now that I ran 6-3 w/ground for my compressor, how do you splice these things? First of all, I know I am only using 2 hot and a ground. As luck would have it I had 45' of it left over from a job that was done in my prior house and I brought it with me when I moved because, hey, you never know when you'll use it ( note to wife: you see it's not all just accumulated junk that I'll never use!
)Anyway, I ran the cable from the box to where the compressor will be. I need to run it into a 6 x 6 x 4 pull box - which is the only way I can see to allow me the cu in req'd to meet fill code. From the box I will run AC to the compressor.
So now I have 3 questions.
1) I think I am supposed to have a cutoff switch near the compressor by code. If so, where do I find such a switch to hande 40 amps, and can I wire #6 to the switch? I was thinking of an AC cutoff, but these are the type that you have to pull out the connector on the inside of the box and is not too convenient.
2) Can I run the non-metallic sheathed 6-3 w/ground through the AC to the compressor if I use the proper bushings on the ends of the metallic AC conduit?
3) If I need to splice the #6 wires, is it better to use a very large wire nut or do I need a split connector?
Thanks for the help. I have been trying to read up on as much as I can, but it seems hard to find answers to these specific questions.
