range receptacle : 3 prong versus 4 prong
lardy1
My house was built & inspected in 1998 and has a 3 prong electric range receptacle. I'm currently installing another kitchen and have duplicated the wiring in the service panel for the new breaker and wire using 6/3 with ground and a 50 amp breaker. Is there an advantage to one over the other? I'm assuming the additional is grounding the carcass but isn't the carcass grounded with a three prong? This is new construction so there is nothing to sacrifice. I want to be as safe as it should be which also makes me wonder about the existing one.
Can someone give this dummy a primer on range receptacles please? Thanks in advance.
Norcal
Prior to the adoption of the 1996 NEC it was permitted to ground the frames of dryers, & cooking equipment to the neutral, now it is only permitted in existing installations, anytime there is a choice between 3-wire, & 4-wire, a 4-wire is the safest & best choice.
