Rapid air hardpipe fitting alternative
vlocci
boston
Anyone have a suggestion for metal (brass/stainless/aluminum) fittings that are compatible with rapid air 3/4 hardpipe?
Piping is powder coated aluminum tube. I have not yet confirmed the OD of their three-quarter inch tubing.
I’m running a compressed air drop into a space that does not allow plastic fittings like those typically used with the rapid air kit
I tried calling rapid air, but was told all fittings are proprietary which I seriously doubt
Anyone know of an alternative for elbows, T fittings and threaded feelings?
PT Doc
Prevost has fittings for their system. Therapy are aluminum with tightening collar. Very cool system.
chompino
TX
I went with Prevost for my system. It was really easy to setup by myself, and I haven't had any issues or leaks at all.
PoorUB
Fargo, ND
Run the Rapidair as close as you can, then convert to copper of black iron. they do have adapter fittings.
Norcal
Proprietary parts are a good reason to stay with off the shelf copper or black iron pipe, I did my shop in copper & need to finish the back room so don't have a hose all over everything to the bead blast cabinet.
