Nedd advice on fittings keep blowing apart under load of 150 psi, 3/4 pipe system rated at 175. followed by the manual and used pipe tread seal. with only 3 stations
I only use steel pipe for my lines only thing I can say is to try and tighten the fittings more and I think they are a compression fitting so I dont think you need to use and pipe sealer
