Torquemada
For decades I've occasionally popped open the drive mechanisms on my ratchets and greased the teeth and bearing surfaces. It quiets them down and I've seen a lot of worn teeth on the cheaper ratchets. Now I'm feeling like an idiot because for the first time I can't figure out how to reassemble my Craftsman 31424 torque wrench.
There are only 4 parts to the ratchet mechanism: The drive cam, the half-moon drive insert with teeth, the ratchet directional controller and a small, bent wire spring that is driving me nuts. A simple hex screw holds it all together. It came apart easier than most ratchets. I greased the innards, but when I went to reassemble it the drive won't turn. I've spent a couple of hours trying to figure out how the spring fits in so that the half-moon tooth insert pulls back to let the ratchet unwind for the next twist. There is a small hole in the half-moon, which I'm pretty sure is for the vertical part of the wire spring. The spring then has an elbow in it, which ends with a U-hook shape. The inside of the ratchet controller has a pin next to a small, raised triangle. I thought the U-hook on wire spring fit over this pin, but when I assemble it the drive won't turn. I've manipulated the half-moon with the wire pin without the ratchet controller in place, and that seems to pull it back and let the drive turn, but no matter how I fit the ratchet controller back on the teeth won't disengage. I'm usually pretty good at these things, but I have to admit I am stumped by this one. Anyone familiar with this model torque wrench and can offer any suggestions?
Thanks.
Thanks.
