Ratchet Rehab - Now I've really done it...
diogenes
The State of Taxation
I decided to disassemble my New Britain ratchet and clean it up. It was failing to lock up and slipping on me and I figured I would see what it looked like inside and see if it was salvageable.
Inside, I found dirt. Yes, dirt. At some point it must have sat in a mud puddle... The innards are not in bad shape and I cleaned it up and I am confident that it will be a smooth operator when I get it back together. Make that "if" I get it back together.
See, the problem is that in taking it apart, I broke the retaining spring clip. When I went to squeeze the ends together one of the ends broke off. I had to pry the other end up and work the ring out with pliers. So, I need to get a new snap ring for it. I have been to NAPA, ACE, Advance and Autozone with no success. None of them had the right style or size.... :dunno:
Anyone have any thoughts about where I can get a new snap ring for this ratchet?
rhastings80
I have even seen a limited supply of snap rings at HD and Lowes. You have to look in the screw and bolt aisle and they are usually in metal or plastic pull out drawers.
D
diogenes
A well equipped hardware store will have the snap ring - there's nothing special about it.
That is what I would have thought... But that's what I get for thinking.
All the places had snap rings, but not the kind (more like a piece of hardened wire) that I need. That's why I'm posing the question. :headscrat
Tool Pants
San Jose CA
Does not sound like a snap ring, but what I call a lock ring or clip.
This is my Craftsman experience with an Easco ratchet. My ring was cut in half when I bought the ratchet, and then I made it worse when I broke the ears off trying to pull it out.
http://www.craftsmantooltalk.com/BBS/Craftsman_Tool_Collection/9158/9158/flat-page4.html
At least I can go to Sears and see if they will take the ring out of a traded in discontinued ratchet and give it to me.
D
diogenes
Damn. That looks awful familiar. I assume you sourced the ring from Adam's collection of parts?
woody 73
The Great State Up North
Hi,
Call MSC at 1-800-645-7270 they will fix you up with the part.
or try fastenal.com
I am having a GJ member make me some New-Britain parts on his lathe so I understand about breaking parts of the ratchet!
dieseldodge01
I don't know if this will help but the ring in mine a a number I-106 stamped in it, i think this is the sizing as all the NOS ratchets have that number, also if you need a kit, PM me I know where you might be able to get one.
