Ratchet wrench with reverse necessary?
bryant 24
From left to right:
1:0 degree flat non reverse, black nickle finish
2:0 degree flat raised panel,spline box;
3:15 offset with reverse, bright chrome(The red is magnetic ring,can be added or not)
4:Flex head without lock,black nickle
finish.
Which one would you like, I like 3 without magnetic ring
ecotec
I prefer reversing with offset. But every configuration has someone that prefers it for their specific use so they are all legitimate.
I prefer the reversing with offset too…
At work I use the non reversible non offset older Gearwrench, because our tools are only insured for a pre negotiated amount.
bryant 24
Yes, but flat without reverse always hurt my knuckle,flex head ratchet without lock is a bad design
u2slow
BC
The reversing ones I have used in the past have one edge of the 12pt defeated so a nut can't pass thru. Thus the reversing is necessary.
I like the ones with the flex head because they can do more, but the hinge in the flex doesn't like hard use, or it goes floppy.
So as usual, there's a case to be made to have more than one type :LOL:
Fedwrench
Valley of the sun
Looking at the picture linked, I think you need to get better ratcheting wrenches. You'd be amazed at the improved performance of a better ratcheting wrench offers.
cannuck
Rural SK
I've maintained for years that if it's not reversible it's garbage. I've yet to see any reason to alter my position.
We have a strict rule that forbids reversible wrenches or ratchets inside of critical devices. We had on fall apart and it took 2 days to find and retrieve the junk. Non reversing ratchets (push through drives) can have more compact head for working in tight spaces.
Madjik Man
Your opinion is highly valued by myself. I've eyed these up in Tractor Supply but have no real world experience with them.
Right now they are $99 for the set on HD. Do you have these wrenches or have experiencing using them?
finn
The UP, God's country
I prefer the offset / reversible type, but, frankly, the flat non offset isn’t that bad once you get used to the lack of offset.
If I can’t find the reversible wrench in three seconds or less, I just grab the non-reversible. Both beat a regular non ratcheting combination wrench most of the time.
BikeRider
Queens, NYC
It's never happened to me but I've used non-reversible ratchet wrenches, the kind you flip over to reverse direction, in situations where there wasn't much clearance between the fastener and some other fixed object like a control arm or subframe, and if I backed out the fastener too far, there was the possibility that the ratchet would contact the fixed object and thus have no more room to move out, before the fastener came out, leading to an awkward situation where I could no longer tighten the fastener enough to remove the wrench, nor remove the fastener.
When I'm in such a situation I either don't use a non-reversible wrench, or remove it before it's too late and back off the fastener the rest of the way by hand or with an open end wrench. My only non-reversible wrench set are stubbies, and sometimes they're the only ones that work in a tight situation, but the very tightness of the situation is what makes using them potentially troublesome. On the other hand the lack of a reverse switch makes them somewhat more reliable as there's one less part that could break, and there's no chance of accidentally reversing direction with your finger, so they're nice to use in situations where this can't happen.
laser3kw
northen IL
It'd be tough between three and four. I'd like three for the magnet to help retain hardware in awkward positions.
Also, got to have reverse.
Fedwrench
Valley of the sun
I own a set of the Dewalts but, they are the older style that came with anti slip open ends. Another great choice would be PROTO, the fully polished versions and the black ones. Both versions are made in Taiwan. Great wrenches!!!
sanddan
Oregon
I have the reversing type. The SAE set is from Craftsman back when you could only buy them from Sears and the metric is a gearwrench set, also from that era. I have one metric non reversing wrench, gearwrench, that I only use if I need a flat one due to poor access. I hate that I always seem to get it upside down and have to flip it to get it to work.
Madjik Man
Thank you. I've never owned an anti-slip open end wrench before. I'll try to hunt those down, if not the non-slip will do.
Protos look nice but at 3x the price it's not worth it for my home game.
bonneyman
Desert SW
I bought my first set of ratcheting wrenches back in 1996. The non-reversible GearWrenches had just come out, and I thought they'd help out with speed and comfort on the jobsite. Boy did they! But that was on A/C units, and some bicyle and home jobs. Never had a "caught" wrench in a tight spot, but my wok didn't have that issue.
Then over the years I'd picked up a few straggler wrenches, offset, reversible, and shorty and long, and came to appreciate the reversing feature. Began coming across units that were the new compact designs, or installed up against a wall with restricted access. Under the hood of my 2004 van I can't imagine my original wrenches working much. So I have a complet set of no offset, non-reversing and about 6-8 offset reversing in various sizes I use.
BikeRider
Queens, NYC
Also, sometimes a flat wrench is preferable, when there's open space surrounding the fastener so there's no need for an offset and you get slightly better leverage and feel with a flat wrench. I don't own any flex head wrenches either locking or floating but I guess that at least the locking ones offer the best of both worlds. But I've rarely been in a situation where I really needed one although I might get a set eventually. Of course, ratcheting, reversible, locking... :unsure:
