Ratcheting flare nut wrench
budget76
with my experience using flare nut wrenches (brake lines) in the northeast, I am lucky to get them free with a normal wrench without stripping. doubt I'd have luck
cool concept though if you have uses and connections that aren't salted to death
5ubtle
Spartanburg, SC
My expectation is that I'd use a quality, non ratcheting, line wrench to "break it free". In my opinion, the application for this is to run the flare nut out of the hole. That sometimes takes a long time using non ratcheting wrenches.
richfinn
Leeds, Yorkshire, England
If I have to crack a brake pipe union loose, I'm almost certainly replacing the rusty brake line (at least since drum brakes and wheel cylinders have all but disappeared in Europe).
Cut the line and use a regular 6 point socket.
I mostly use line wrenches on fuel fittings nowadays, once they are loose you can unscrew by hand almost every time.
I think they are one of those tools that seem like a great idea, but in reality you would be better served spending $$$ on real problem solver tools 🙂
dchawk81
That's my method too. Usually the line itself won't survive any kind of twisting anyway.
I treat the plastic air lines on my truck the same way. Just plan to snip it off, use a 6 point wrench on the fitting, and add some line and a union.
I'll try to save it first but I don't expect it.
5ubtle
Spartanburg, SC
A positive review of the Amazon wrenches that I linked above:
The Amazon product page states "Date First Available: January 22, 2021"
A similar $200 set on Amazon.
Date First Available: July 17, 2020
The Patent No. in the description (8166849) was filed in Dec 2009.
Tribus Tools ratcheting flare nut wrench demo from 2017:
Made in USA and possibly the original.
Tribus apparently recently went out of business.
https://www.tribustools.com/
A negative review of the Tribus wrench:
(Don't watch if you are offended by foul language)
SK wrenches like the Protos SpeedBump has used:
5ubtle
Spartanburg, SC
I bought a 15mm RatchetFix brand from AliExpress for $18 delivered.
I haven't used it on a flare nut yet, but I did some testing. The ratcheting mechanism seems strong enough. The first "point of failure" that I've experienced is the wrench spreading and allowing the nut to rotate "out of register" (see picture). When this happens, not only is it done turning the nut, but the wrench is difficult to remove from the nut because the ratchet is not reversible. This happened on my wrench somewhere between 40-45 ft-lbs. A conventional, Bonney flare nut wrench was able to get to 60 ft-lbs on the same setup (it might have gone higher, but that was enough for me).
colintrax
I have that SK style wrench, also made by Wright, mine are vintage Bonney.
They've worked well so far but I wonder if they're as good as traditional
lugnut71
Wyoming
I know the guy that designed the tribus and got the patent,etc younger man , smart, mechanics full time for Caterpillar, cant blame a guy for trying . Assuming he had to find someone to manufacture them. I would imagine its a big and expensive commitment to get the ball rolling.
u118224
Northern MI
Off topic, but I recently saw a lot of Renault Clio's in Portugal rockin' the rear drums. I think they're the official rental car there.
jsackin
Kansas City Missouri
Just got a deal on these sets from a government supplier. Most people that find them useful are refrigeration guys. The ones we got say "Stride". Have some random Bonneys in the basement and I've seen Wright and SK also private label these as well. Wouldn't be surprised if Stride was the one that was making these for everybody but not super familiar with their line. I've also seen ratcheting crowfeet on government deals, but they're usually really big.
GeoBruin
Well, I just bought these. I've been contemplating the ratcheting flare nut problem for some time and this style seems like the best combination of function and strength. Plus the size range on this set is great. Thanks Jori (is it Jori?)
colintrax
I actually got my small set of Bonney from yall
bonneyman
Desert SW
If I were starting out in HVAC again today I'd just get a set of those Strides from Epstein's. (y)
5ubtle
Spartanburg, SC
I have a feeling they'd be more trouble than they're worth.
Everybody is going to have a different tolerance for aggravation. I won't be buying any more until I have a specific use. If I could get a set of 7 (or so) from 8mm to 19mm for about $50, I would buy them before needing them. The current price of $150 for a set of 9 is not for me.
That was all I ever needed to see to know I would never buy a set of any wrench in that style even if they were free just pay $1.99 s/h.
I think that my wrench is better made than the Tribus wrenches that JUSTIN STURGILL TRUCKING was showing.
demarpaint
Long Island
I agree about different tolerance for aggravation, but I see even $50 for the set you described a waste of $$. For the few times a year I might need a line wrench I grab my Stahlwille flare-nut wrenches and not worry about having a problem. The ratcheting design looks like a headache in the making. The possible slight gain in time using a ratcheting type line wrench doesn't matter to me.
Marsim
I got a partial set of nos imperial strides for $1 a piece at a flea market a few months ago. They're ok, but no way would I pay full retail for them. I use this one alot, works 10x better.IMG_20220915_081433860_HDR.jpg
