ratcheting flare nut wrenches
Zaylor
Alaska
I saw this design for the first time at Princess Auto.
I have seen other designs of ratcheting line wrenches, but this seems superior.
Has anyone out there used them, and would you be willing to give your opinion?
Thank you
Z
Zaylor
Alaska
I've gotta say, those look pretty slick. How do they feel in person?
They feel good in the hand. The ratchet mechanism actually felt like it would work. I wanted them.
However, I have no experience with Princess Auto, and they have a lot of gimmicky stuff.
I also don't live in Canada, so can't bring them back if they break.
bonneyman
Desert SW
Looks like a relieved 6-point broaching. Nice feature.
The metrics could be a real help nowadays. :thumbup:
niferous
Houston, TX
I have a metric and SAE set of the Wright Tool ratcheting flare nut wrenches. They work very well and I hardly ever use my traditional style flare nut wrenches any more.
superautobacs
Vancouver, BC
My first one was a fixed head with a regular open end on one end. I've since added a couple flex heads. They have worked for me, but I've only used them a handful of times. They have a bit of a gimmicky feel. The black and red plastic rings can come off if you're not careful. I would be weary of using them in dusty, grimy environments where sand and other foreign objects could enter the ratcheting mechanism. They have a bulky head as well which might be a limitation.
Z
Zaylor
Alaska
Fantastic pics!
Great point about contamination to the ratcheting mechanism. It's kind of like an older open head ratchet in that way.
Do they still work without the plastic rings?
I figured I could use them to spin things on and off, and still use my solid line wrenches to break things loose. There are a lot of times I am turning a nut on a brake line, and it is too much torque to turn by hand so I am stuck doing 900 25degree rotations with a traditional end wrench or line wrench.
gdocktor3
Connecticut
Astro Pneumatic makes some and they've gotten good reviews. Plus, there is a rep on here who will take care of you if you have any problems. http://www.ebay.com/itm/5-Pc-Ratche...1040e19490e506cd682acd&pid=100508&rk=1&rkt=1&
I've used Imperial ratcheting flare wrenches like these for years and they work great, if there's enough room for them... Proto, Armstrong, and others also make them like this http://www.ebay.com/itm/IMPERIAL-KW...:g:OwwAAOSwoudW3Kx8&item=201536471629&vxp=mtr These are the new design http://www.ebay.com/itm/IMPERIAL-19...585394?hash=item27fc895db2:g:g0cAAOxymxFRmjmV
