Ratcheting, multiposition screwdrivers
dscheidt
I don't know, but I've had that screwdriver (and a couple different length shafts) long enough that I paid $50ish for it... It's one of my favorite screwdrivers.
Midwest
I use a Stanley ratcheting screw driver that I picked up from Meijer's believe it or not. I use it everyday for the the past 3 years and it's still going strong.
It's the 62-574 to be exact.
G
gdpolk
Yea, I have a pile of regular screwdrivers laying around but this one just look plain handy. I'm a DIY guy and while I do own some SnapOn stuff, most of what I have is mid-grade stuff as it seems to be a much better value for me.
I have a small handheld box that is my go-to for 95% of what I need to do and then a bigger SnapOn cabinet in the garage as my "home base" with everything I need for anything. Right now in my small box I have a SnapOn square handle stubby and mid length P2, a SnapOn stubby and mid length flathead, and a cheap old Craftsman bit driver with a small selection of bits. I just became privy to this flex handled design of a ratcheting driver and I just kind of want one.
If I can find one that offers the same utility as the SnapOn for a bit cheaper then I'd love to go that route instead. If not, I may swing for the SnapOn.
Midwest
I think I'm the only person who doesn't like using ratcheting screwdrivers
They aren't ideal but when you're dealing with screws that haven't seen the test of time they work great. Especially when the torq spec is "Torque to mating part". Lowest torq spec I go to is 1.5 Nm. I use a 1/4" drive SnapOn to hit that with out over torquing.
gahrajmahal
Cincinnati, Ohio
I have a Black and Decker cordless screwdriver that does what this one does but unscrews the screws when you push the button. It is about 7 or 8 years old now and the battery still holds a charge. I always have it when I get ready to paint a room removing all of those cover plates and light housings. Works great disassembling electronic stuff like toys, computers and stuff.
ChrisLS8
I usually use a 4v driver for interior work but I do like my Williams though it isnt multi position
Danglerb
SoCal
As much as many here love all things Snapon, when it comes to screwdrivers preferences will vary, and best thing to do is just try some different ones.
Anytime I start thinking a job would go better with a ratcheting driver, I also start thinking it might go even better with a powered driver.
dan.brown
I have a few different Snap on directional screw drivers. I do not like the newer model I have with the 1/4 turn cap. The damn thing is always popping off. I prefer the older ones that I have with the screw on top. I use them when I am going to use a hand screw driver. I use my Makita more often than not. Just slide the bit in and go to work. I even use it for straight screws. But I find that the multi directional screw driver works better for the straight slotted screws.
Sent from my SM-N910V using Tapatalk
Mikeske
Washington State
I have the straight on ratcheting snap-on screwdriver
https://www.amazon.com/dp/B0771CDXHS/?tag=atomicindus08-20
I like the straight on design. The one that pivots I hated it as I would hit the release and it would not stay either straight or it would pivot when I wanted it at a certain way. I bought one and after a couple months I just hated it so bad that I gave it to my nephew and he broke it and got it warrantied to replace it. I also have the stubby (great little guy) and the t-handle and I like them just the pivoting one was one that I did not care for.
ocloc24
I've used several and I think this is one area where snap on is worth it. Very fine ratchet action and super comfortable. I love it so much I just ordered a 2nd one last week for home
Tonyuk
Scotland
Bahco have one;
They're owned by snap-on, the internals probably aren't much different if not the same design.
Metalio
NL
I have a multi-angle one made by stanley but the ratcheting mechanism is half broken (still works but will slip on occasion) so I don't use it anymore. I also have a regular ratcheting screwdriver by stahlwille that's the same design as the bacho and SK ones posted here, I believe those are all made in taiwan by the same OEM, and that's still in good condition after a few years.
ryan20021982
Northern IL
Yes they are all the same as the SK I posted earlier, these are all the same mechanism and all Taiwan.
View media item 69508
