I own 6 Ryobi batteries, 2 DeWalt 12v batteries and 3 Masterforce 20v batteries. I dont care what kind of battery you have, if it sits in your toolbox drawer for a year and you go to use it, the battery is probably going to be dead. Thanks for playing though.You must not own any Li-ion batteries or you are to lazy to put them in the charger.
The SO long shaft hard handle ratcheting screwdriver is the one to have.
Good luck
Amen. I work in auto manufacturing and they give us Milwaukee M12 and Makita 12v impacts to use for shooting small bolts and screws. I often feel like some of the people I work with probably shouldnt be given anything more than a 4v powered screwdriver. LOLI fully support this rule.
I love these vessel screwdrivers.Try this one for $14. If you are going to be ratcheting, the ball is very nice. It’s also nice to hold the ball in your palm and turn the lower part with your fingers for fine control
Vessel 2200B
I had acquired a damaged Snappy ratchet driver, and - was bored one weekend - so installed the Snappy mechanism into an empty EASYDRIVER ball. Best of both worlds!
Vessel 2200B
Thanks a lot, look what you made me do.I don't use my ratcheting screwdriver much, but I still like having it.
One of the aspects I find handy is being able to hold the handle with one hand to keep the screwdriver straight and quickly spin the shaft with my other hand - then finish up with torque. This is handy on machine screws like you encounter installing electrical outlets and switches because they use flat-head screws and being off-center makes it easy to slip out of the head.
Often if I am doing a lot of rapid turning, I would rather use a cordless screwdriver - but a ratcheting driver still has a place (especially as a kitchen drawer, tool bag or belt multi-bit driver).
I like my Rolgear ratcheting screwdriver a lot. Almost non-existent back drag means it ratchets even on machine screws that have very little resistance. It's also a clutch-style ratchet mechanism, aka a "zero" degree ratchet. It uses the longer-style bits that are better for access. Made in Canada. Very nice grip.
The Rolgear replaced my Picquic multi-bit screwdriver in my mobile tool bag - which I consider high praise, because space in that bag is at a premium.
On the otherhand, I don't use it in my shop basically ever. I'd rather grab a Bahco/Irazola, Felo or Wera fixed-blade driver from my tool chest (or reach for a cordless driver if there's a lot of low torque spinning to be done).
Edit:
I was obviously typing my post while LukeOrest was doing his too. I am seconding that Rolgear recommendation. Very nice ratcheting screwdriver.
I have a Craftsman similar to that one, but it just has a full acetate handle on it - no bit storage. I use mine all the time for household stuff and car trim panels. I also have some little bit driver ratchets for when the space is too tight even for a stubby, and they have worked well.Back in the day I had the craftsman ratcheting bit holder screwdriver. I loved the ratcheting action, but I kept breaking/stripping the cap on the end because when I would really lean on it for max torque, the cap would turn, and I'd either strip it or crack it. Eventually I just dumped it out and used it without the cap. But then it was uncomfortable. It was like this one (pic stolen from google):
I never really tried another until I got into collecting xcelite/vaco drivers. I have a vaco ratcheting screwdriver that is almost identical mechanically to the old craftsman, except the cap is much more stout. I don't use it much, but it doesn't feel like it would break easily:
I also have had several versions of the Xcelite 99-1-R and 99-4-R ratcheting handles.
But as others have said, as I got older, and cordless technology got stronger and more compact, I almost always reach for my impact anymore.
Ha! You'll have to let me know what you think!Thanks a lot, look what you made me do.
I won't ask anything for any clarity, what-so-ever. Good on you mike! have funWife has a regular snap on ratcheting...
Using my cordless, I can get one of these in where a stubby won't fit:They are nice to have.
You're high as a giraffes' gonads if you think you can get a cordless so and so in where a stuby ratchet will just fit.
