Fedwrench
Granted, this is Matco propanganda on you tube but, it compares the failure point on a Snap on, Gearwrench, and a new Matco ratchetig 13mm wrench. Judge for yourself.
It illustrates something that has been debated here many times, breaking fasteners loose with a ratcheting wrench. If anything, it shows that there's no sense in spending big money for a truck brand when Gearwrench will get it done for a lot cheaper.
Interesting test, but nothing in that video made me think I have to own Matco wrenches. 140 ft-lbs is more than I need in a ratcheting box end.
What kind of a ***** breaks bolts loose with a ratcheting wrench, let alone with a cheater pipe on it? What a stupid test.
All of them seem ok in my book,if you have to use a cheater pipe on all 3 of them to push them to failure.Can you put 140 foot pounds of torque on a standard length wrench by hand? And are these the new ratcheting wrenches made over seas with the 90 tooth internals? Funny that it shows the GW wrench taking more torque than the only USA made wrench in the test...
What kind of a ***** breaks bolts loose with a ratcheting wrench.
Just about everyone who wrenches full time i'd wager. Sometimes all you can fit in a space is a ratcheting box end. I'd also go a step further and say most have also at least chain linked the wrenches to get more leverage.
72 teeth basic 12pt. The only ones with 90teeth are spline drive and are reversible. The 7 series demonstrated are made by Kabo of Taiwan. They also arent priced too terribly for a truck set (8-19 for $155). The Snap-On set would run $350. Neither are stamped USA.
This is garbage.
I was under the impression that the Matco reversibles were identical to Armstrong reversibles and also made in the USA?
Are the wrenches tested a different series?
If Matco had as much problem as I did with the USA made wrenches, I don't blame them one bit for switching to Taiwan.
That said, my Snap-on have NEVER come non-functioning out of the package.
Assuming it's a combination, there's an open end on the other end, why not use that?
on a stuck fastener? excellent way to destroy a couple sides of the bolt/nut, the wrench, your hand, or all 3.
- does anyone make a ratcheting wrench with a box end?Dumb question- does anyone make a ratcheting wrench with a box end?
Skin; Just about everyone who wrenches full time i'd wager. Sometimes all you can fit in a space is a ratcheting box end. I'd also go a step further and say most have also at least chain linked the wrenches to get more leverage.[/QUOTE said:Chain Linking wrenches is my favorite way to break tools! I have only broken a couple of wrenches in my time and every single one of them was linked up to another wrench when it happened. I have done this more times than I can count and will get you out of a tight spot (literaly), but can also be hard on tools. I will add that i have done this far more times with zero problems than the few where i have had something fail.
For us pros, sometimes you have to abuse a tool because you can't call uncle on a job just because you don't have a tool that will accomplish the task while being used in a manner it was designed for. Sometimes you gotta do what you gotta do.
Rather that than destroying or reducing the lifespan of the ratcheting wrench.Wait a Minute.. Its Better to use the open end to break loose a Fastener versus a Ratcheting end?
LOL
Flat raters can't be using one wrench to break a bolt, one to spin it, and one to tighten it. You will never get anything done changing tools every 10 seconds. So guess i'm a *****.......
Hell, I bet my ratchets would last longer if I used a breaker bar instead in every single instance where it was possible but it would sure slow me down.
Sometimes these threads help illustrate which members are the Harry Homeowners and which are the battered bastards down at the repair shop.
.......The video isn't about using the right tool for the right job.It illustrates something that has been debated here many times, breaking fasteners loose with a ratcheting wrench. If anything, it shows that there's no sense in spending big money for a truck brand when Gearwrench will get it done for a lot cheaper.
I wished they would have used current Kobalt, Titan, and Mac edge. EZ Red, I'd like someone to test those EZ red wrenches to failure. How much does one of those torque testers cost any way?
I think Matco's point is that you'll bend the wrench before the Kabo made ratcheting mechanism will fail.![]()
