Ratcheting wrenches options
Ohio Andy
Columbus, Ohio
Only possible concern I have is they are extended length, so they are longer than a standard combination wrench, especially the larger sizes. Remains to be seen if this will be a issue or not. Overall however, I'm happy with them upon 1st impression.
You have significantly more wrenches than I do, but I do have an extended length flexible ratcheting set... And you are correct in this. But sometimes that extra length is really nice...
2ndGearRubber
Pittsburgh
First, I have Snap On combination wrenches up to 24mm. Worry not. I also have Snap On angle wrenches up to 22mm. A ratcheting set is just to expand my capabilities.
That said, I went to HF on my way home from work and decided to buy some things.
#1. I bought the 10mm to 19mm Icon reversible ratcheting wrench set with anti-slip ("flank drive") open end and 15* degree offset. The ratchet mechanism feels good, solid engagement but no, they're not buttery smooth like Snap On because they're not Snap On.
HF also sells an add on set up to 32mm I might have to buy later.
#2. I also bought the 3/8" Icon 10mm to 19mm impact wobble socket set I mentioned in another thread. Again, initial impressions are good. They feel solid. I like the roll stamping. Much slimmer than they look online. I think they will do the job just fine.
#3. I came across a 1/2" Icon metric hex set on clearance for $20. I don't need it, but I was looking around at larger hex sets recently and for $20 I wasn't going to pass these by. Completely unopened or touched by the way, NOT an open box return.
Nice find on the hex bits. Please post up a review of the swivel sockets when you get some miles on them. I don't think I've seen any in-use opinions on them. The length on those wrenches is impressive. Almost as though its take some inspiration from the long offset wrench style.
at what point is the type 1 regular reversible combination offset ratcheting wrench too big to be considered useful? I was thinking maybe 24 mm?
with 27 and 32 the fastener is going to require so much torque I’m not sure if a ratcheting wrench can handle it your prob better off with a XL 1/2 drive ratchet if it can fit and if it can’t fit then what engineer designed a thing with a 32 mm bolt in such a tight space a socket won’t fit?
I think usually the bigger the fastener the more space they design in but I mostly work on 2000 to 2015 year cars tbh
IMO around 24mm the head of a ratcheting wrench is so big it no longer fits versus a socket. Although I know brands make up to 32mm for industry/building type stuff, or for driving other tools. I have a long 1" ratcheting wrench for my power steering pump pulley puller (say that 3 times). Lots of tools and equipment for automotive still are in SAE.
KnurledNut
n/a
Solid choice. HF did right and sourced all their various style ICON ratcheting wrenches from high quality manufacturers. These are a standout in the ICON line. I do wish they would stop with the overkill packaging and apply the savings to the product cost. If you decide these arent what you need, they should re-sell quickly and seem to hold their value.
I have the set you bought, but with the smooth non-modified open ends. The long length can be a help but also a hinderance. Lots to love about them though, and there's not too many other decent priced options for a reversible long pattern. They are a good compromise between standard length and extra-long. I was going to recommend those when I read this thread initially but decided to sit it out and see what others had to say first.
Also, check out the ICON stubby flex. I have them as well and they are more of a short pattern versus full stubby. They would be a good complement to your set for limited access and quick speeding. I have the regular ICON flex too but would recommend the short in your case.
The Williams flex reversible @Drunkonunleaded mentioned above are great but spendy. I keep some of the smaller sizes of those within reach.
I could ramble on about ratcheting wrenches for much longer than any of you guys want to hear. I'll stop here. :lol:
Hakeem
Chicago
I have that same set of ratcheting wrenches. They are comically long, possibly the longest ratcheting combo wrench on the market. The ratchet mechanism, by InFar I believe, is little more “clicky” than the Kabo ratchet mechanisms but still works well.
The ASD was an unexpected bright spot. It really does work, not as well as the flankdrive+ style wrenches with teeth in the open end, but it won’t mar fasteners, either. the looser fitment of the open end is helpful for rusted or otherwise swollen fasteners.
Let us know what you think after some use! I like my icon stuff but I’m just a hobbyist. I’m interested to hear what an experienced (former) pro thinks.
Hakeem
Chicago
Yes, my thoughts exactly. The ratchet wrenches are the best offerings at HF. Good quality, reasonable prices, and most importantly for ratchet wrenches: very good warranty.
I, too, have the stubby flex ratchets and would also recommend them. The length is ideal to me: short enough to fit most places but still long enough to where I can grab the shank with most or all of my hand. The really short stubby models from Gearwrench or Olsa might fit more places but the ultra-short shanks make them less versatile.
I can’t speak for others but I’d love to hear your ramblings on ratchet wrenches :lol:
cgrutt
I have the long pattern reversible ICON set as well as the non reversible flex head set. I just used the long pattern yesterday on a rusty suspension and was very impressed with them. Put a fair amount of torque on them both directions and they worked great, operated smoothly and felt good in my hand. Definitely like them. I got the flexible wrench stuck first time I used it on a different project and wound up bending the handle in order to free it up. Harbor Freight replaced it even after telling them what happened so warranty wasn't a problem but just the fact that I was able to bend the handle has me a little put off with them. They work fine just need to be careful when using the non reversible head. I'd like them better if they were reversible and may replace set in future.
A
AJHD
Only time will tell if the extra length will pose any issues. My guess is a combination of both pro and con just depending on the situation (what I'm using them for at any given time).
In the future, I will pick up a shorter or stubby variant. But for now, I'm happy.
Zebu Fellenz
Phelps, NY
For ratcheting wrenches I have sets of flex head gearwrench combos, stubby gearwrench non-flex, and armstrong zero degree non-reversable combos.
Armstrong are the nicest wrenches by far, flex head gearwrench get the most use and the flex head comes in handy all the time, stubby gearwrench are super nice for tight spaces and loosening fasteners that are almost loose enough to remove by hand.
2ndGearRubber
Pittsburgh
If they sold singles at HF it wouldn't matter as much. Chop one in half if need be, buy a replacement later.
ecotec
The NOS Blackhawk ratcheting wrench sets are often found for quite cheap. I would place them at a little longer than short pattern, though, not stubby.
The set that I have is not complete. It is only 10-16mm. It was so cheap, though, that I could not pass it up. I paid closer to $15 than $20 about 10 years ago.
They are another option.
I still don’t have a stubby ratcheting wrench set. I shall put it on my list.IMG_4371.jpeg
908Jim
#1 all day for ease of warranty alone. They remind me of the USA made craftsman/Armstrong reversibles that I regret not buying in metric.
I have flex head metric gear wrenches that I paid extra for and I can't recall the last time I thought "Wow, I'm glad I have the flex head!"
Odd-job
Oh man this thread made me just realize I am a classic GJ member tool hoarder as I have all 3 options + Option #4 = Mountains.
OP made a good choice with the Icons/Kabos which probably cover the widest use cases of the original 3 options. #2 works well in stubby form when needing to get a something in a tight place where turning a traditional combination wrench *****, but hopefully one doesn't have to use this every day. #3 zero offsets really have more limited use cases, if one were to invest in these would consider these more in the larger sizes for let's say suspension work.
Only value added comment I have is that the 8mm that is not included in the standard 10-19mm sets might be worth getting at some point.
A
AJHD
I actually had a set of the Mountain wrenches at one time. I ended up selling them a few years ago. I found them to be awkward and difficult (or impossible) to fit into most spaces. I've also had the Snap On double box end zero degree offset wrenches but sold those too.
Hopefully this Icon set doesn't give me the same issues I had with those sets. Although as previously stated, I will likely pick up a shorter/stubby variant of some kind later on either way.
I know from experience having longer wrenches can be both a hinderance at times but also necessary at other times. I can't reminder make/model it was, but one example was replacing the front upper control arms on a pickup truck. The passenger side had clear access to the bolts above the wheel beyond the fender. But the driver side had some brake lines and ABS **** in the way. I could not have done that job without a longer ratcheting wrench. Even a ratchet and stubby socket would not have fit.
Anyway... I'd like to pick up an 8mm, 21mm and 22mm reversible ratcheting wrench to compliant the Icon set. I don't use those sizes as much, especially ratcheting, but they will be good to have on hand. I just need to decide on what brand/option best compliments the Icons.
Odd-job
100% agree on the Mountain wrenches. I reserve them for special situations. Usually when I need some leverage, but have some slight access issues where the flex head is convenient and there is enough space to swing it. This being said am also scared of breaking them.
Wrench97
Southeastern Pa
I use long and regular 21 and 22 all the time in suspension work.
Kurt4440
Western New York
Am I the only one using these?
This is the only type of ratcheting wrench that I use.
I thought about old ratcheting wrenches last night while I was reading the thread. I have a few sets of those old style in standard and metric. The metric set is in my Ford Expedition.
Then I have some assorted oldies but, I mostly use; power tools, ratchets and then wrenches.
The long double flex SK ratcheting wrenches get used the most out of the ratcheting wrenches.
There are a couple of stubby sets in a different garage.
Here is a representative sample of some of the sets that I have.
L.Cheapo
I own a set. I keep them in a dirty cardboard box under my toolbox with the other misfit tools. Can't bare to throw away tools, for fear that *something * might come up where it's the only thing that will work.
cannuck
Rural SK
I have a bunch of ratcheting wrenches that have accumulated over the years, but I use them so seldom I couldn't even tell you what brands they are. Much of my work has fasteners too close to components for the bulk of
those wrenches to fit, so they just take up space in my box.
I also have an aversion to reversing wrenches: I worked on large power transformers for decades as the mechanical guy, but as a contractor my advice on tools was "optional" to some people. We didn't allow (or weren't supposed to use) anything inside of the tank that could fall apart - as retrieving something inside could be extremely difficult and 100% HAD to be found and removed. An enterprising CEET figured that a ratcheting box on a tether would meet that requirement. I often criticized these guys for buying cheap tools that weren't appropriate on multi-million dollar equipment and this time the cheapo ratcheting reverse switch fell apart while working inside a "shell wound" transformer (winding on horizontal axis instead of usual vertical. Those little bits of steel shut down a significant portion of a large city utility for two full extra days until some megabux rental high resolution inspection cameras finally found the detritus. Using a cheap tool meant probably fifty grand losses to the utility and cost of 2 non billable crew days probably another 20k to us.
impactims
What about the design makes them better to you? Just curious.
I’ve had numerous modern ratcheting wrenches “jump” and skip teeth under load. Never happened to me with the original designs with the same and even with greater loads. Modern gear wrenches have also came apart completely during use. Never with the originals. I have many of the originals that have decades of abuse and continue to perform like new. I also like the serviceability of the originals. Easy to clean and lubricate. The modern gear wrenches are not serviceable or at the very least not as serviceable. I also like the coolness factor of the originals and I like how the mechanical components are visible.
A
AJHD
BrandonV
Arizona
Hmm... Interestingly enough, Snap On seems to still make them and sell them.
As I said, I don't think I've ever actually used that style/design before, but it'd be interesting to buy a commonly used size (maybe 10mm) and see how I like it.
Metric - https://shop.snapon.com/categories/Standard-Handle,-0°-Offset,-mm-(Ratcheting-Box)/675012
SAE - https://shop.snapon.com/categories/Standard-Handle,-0°-Offset,-inches-(Ratcheting-Box)/675011
I think Lang might make these for all the big brands (Wright, Klein, etc.).
KnurledNut
n/a
I used a laminated Snap-on 3/4 & 7/8 for J-bolts in hard to reach locations. It was great because those two sizes covered standard and heavy hex nuts which are both used on 1/2 bolts. The open gear design was easy to keep clean; it was always dusty, wet, muddy, sandy. I had one lock up from years of use which Snap-on warrantied. Overall, good wrenches for suited applications, not so much for confined spaces of automotive.
I also had a Mac 6 point 1/2 & 9/16 that saw a fair amount of use and never failed to work.
Craftsman sold some that were kind of unique having a screwdriver handle. I believe they were called Ez-Grip. I have a single 10mm. Cool but limited use. Whats not to like when you can have both stinky and coarse tooth in one dedicated tool? :lol:
SkinnyG
Orange Park, FL
If I had to pick from those 3 options, I'd chose the flex head without a second thought. The flex head allows for so many angles for clearing obstructions. I'm the same with ratchets - I typically won't even use one if it's not a flex had. And none of that locking bs either. I want to be able to pivot the head as I'm moving throughout the swing. I know that seems to be a problem for some that insist on using locking flex heads. I can't get it through my head how or why it's a problem without a lock.
You specifically state "non reversible flex head" but there are reversible options. My go to ratcheting wrench set is a Blue-Point reversible flex head. Another neat feature of that wrench is the ratcheting portion is 12 point but one side of the box has a thin 6 point edge. That way, you can set it on top of a nut or bolt and it the 6 point edge prevents it from slipping down. It's handy on some rare occasions.
It seems the price on these things has gone up (or doubled) since I got mine 15 or so years ago.
https://shop.snapon.com/product/Flex-Head-Ratcheting-Combination-Standard-Handle%2C-15°-Offset%2C-mm-(Blue-Point)/12-pc-12-Point-Metric-15°-Offset-Flex-Head-Ratcheting-Box-Open-End-Wrench-Set-(8–19-mm)-(Blue-Point)/BOERMF712A
Edit: Well pasting the link didn't work...
Kurt4440
Western New York
I occasionally use the 7/8", I keep one with my Astro Nano 1/2" drive sockets.
