Dakotadadv8
- Joined
- May 30, 2021
- Messages
- 1,508
Also thinking about buying additional ratcheting wrenches but don't use them often, prefer my SO standard combo wrenches. May buy a few SO ones to supplement them.
Especially for non-professional use, I agree with this.I think it's important to determine who the OEM of the wrench set is, rather than the brand name that's on the wrench.
Westward (Graingers house brand)Who makes ratcheting wrenches bigger than 1" and 24mm? At work I use a lot of 15/16", 1 1/8", and 1 1/4", 24mm, and 27mm stuff, a 36mm would be really nice for 1 particular job we do. I have a 2 year old set of non reversible standard gear wrenches to 1 1/8" and an O'Riley set of metrics that skips a lot of sizes. I haven't broken one yet though the internet claims they are garbage. My wrenches get filled with slurry and usually a good wd40 bath gets them functioning again. Being able to take them apart and clean them would be really nice.
If I was to upgrade there aren't many professional brand options. It looks like snapon stops at 1" and is the only tool truck for 500 miles. Proto is the one professional brand I know of making bigger ratcheting wrenches. Does anyone know of another higher end brand offering bigger ratcheting wrenches?
ThanksWestward (Graingers house brand) ...
All these sizes are also available from Gearwrench.
https://www.paperturn-view.com/us/apex-tool-group-naht/gw-catalog-book?pid=NjY66929&p=227&v=9.50
Been there done that...10-4.Thanks
I already have cheap import gear wrenches. Looking for options if I decide to upgrade to something "pro grade". I haven't killed the so called garbage gear wrenches in 2 years using them to make a living though might upgrade if I break one or they get too rocked up with rock dust or slurry from gold bearing ore. The tools we use in the mining world are a lot bigger than automotive or your average hobbyist and can be pretty hard to find bigger sizes of things. Most of the higher end ratcheting wrenches stop at 1"
I grabbed a set of these used at fair money off local marketplace as liked the design effort in screw assembled head.From what I’ve seen, ratcheting wrench’s mostly fall into one of 3 categories, and within that category there is almost nothing to distinguish between brands, other than pricing/finish/warranty.
- reversible with 15* offset
- non-reversible with no offset
- flex-head
The only ratchet wrench’s that stand out as different from the long list of Taiwanese rebrands, are the snap on dual 80s, because they have a much thinner wall width at the ratcheting end, so allow you to use a ratchet wrench in tighter spots.
It’s a matter of personal preference/what you’re used to. Personally I don’t like the straight non-reversible ones, that bit of offset helps access, and don’t like flex heads because I don’t want it to flex when I’m leaning on it at an angle. For me, my 20yo bluepoints work great, and I don’t find the thickness an issue often enough to spend $700 on the dual 80.
Let’s see a picture of the two wrenches side by side for comparison I’m having a hard time seeing the disadvantage here.I grabbed a set of these used at fair money off local marketplace as liked the design effort in screw assembled head.
While the ring looks thin what I have found with them is in tight spots the head bulk where the screws are drastically reduces your arc swing and my facom perform best in tight scenarios by a big margin and pre covid the facom could be had around 170 bucks 12 piece set(was like 100 bucks direct in Europe) . The long patern HF ICONS made by high-five manufacturing partners is a nice set of reversible wrenches and was under 100bucks in early release days, can be seen pretty cheap on eBay at times, not an everyday set but is a nice handy tool with the extra reach/leverage .
Also missing 25mm/1" ? I wish HF sold these individually so I could mix/match SAE/Metric and leave out the ones that are "close enough." As is it is I'm not willing to pay for both sets.I dont know if there are Harbor Freights in AK, but these ICON's would probably be good wrenches with easy warranty:
https://www.harborfreight.com/profe...MIlMeii9Hl-QIVMciUCR0y5QwkEAQYASABEgJnvPD_BwE
You Could save some coin not getting a full SAE set.
24 covers 15/16
27 covers 1-1/16
30 covers 1-3/16
32 covers 1-1/4
Basically only leaves needing 1-1/8.
That Williams set is identical to the last gen snap-on set I had before the dual 80s came out.Also missing 25mm/1" ? I wish HF sold these individually so I could mix/match SAE/Metric and leave out the ones that are "close enough." As is it is I'm not willing to pay for both sets.
In the smaller sizes, I like the US-made Williams ones, metric set is p/n MWS-10RCU. Not cheap, tho.
Not 100%. The wrenches are forged and assembled in the USA.In the smaller sizes, I like the US-made Williams ones, metric set is p/n MWS-10RCU. Not cheap, tho.
Correct… and they are not stamped USA. They have little paper tags tied to the open end of each one that say made in USA.Not 100%. The wrenches are forged and assembled in the USA.
...followed by flex head ratcheting stubbies...
Although 25 mm and 1" aren't standard head sizes for any common fastener series. Only would come up in oddball stuff where some designer picked their own arbitrary size.Also missing 25mm/1" ? I wish HF sold these individually so I could mix/match SAE/Metric and leave out the ones that are "close enough." As is it is I'm not willing to pay for both sets.
6 pt can be a pita at times if they fit too tight they get stuck on takes extra to get them off.Amazon has them:
SK Professional Tools X-Frame 6 Point Metric Ratcheting Combination Wrench Set 7 pc. - Case of: 1; Each Pack Qty: 7; Total Items Qty: 7 - - Amazon.com
SK Professional Tools X-Frame 6 Point Metric Ratcheting Combination Wrench Set 7 pc. - Case of: 1; Each Pack Qty: 7; Total Items Qty: 7 - - Amazon.comwww.amazon.com
Speaking of... I had to purchase a 21mm 12 point wrench to remove my SCR straps. An open end won't fit and the stud is on too sharp of an angle with its own hardware to slide a socket over and hit the nut. There isn't enough swing clearance with a 6 point to move the nut enough to reattach.6 pt can be a pita at times if they fit too tight they get stuck on takes extra to get them off.
I've had an old gearwrench flex head stubby set for several years. I'm not sure on the quality of current versions. The Icon short flex head ratcheting wrenches are short but, not really stubby. Dewalt also offers a short handled flex head wrench set that seems good. Vim makes those super stubby ratcheting boxed end but, they more like a toy than a real tool.What's a good brand of flex head ratcheting stubby wrenches?
I have the Icon flex head regular length (Kabo?) and like them a lot. The Icon flex head ratcheting stubbies are fairly long for stubbies, I think.
There are Gearwrench flex head stubby ratcheting wrenches, and though I think they've remained a Taiwanese mfgd wrench even till now, they're actually kinda expensive, I think.
Given that the Icon flex heads are reasonably cheap and abundant in offerup/Craigslist here, I was considering buying a set and cutting them down to stubby length - I certainly don't need yet another set of open ends...
SK X-frame are the best IMO.Looked through tons of threads and I know suppliers change over the year - my questions
IS the Snap-On top level?
Then is it Matco, Icon, Carlyle?
Lowest GearWrench, and all the autoshop, Walmart, different cheap rebrands?
Facom sells a Series 65 DBE wrenchQuestion: does anyone other than Blue Point sell a double box end (DBE) offset, say around 15-20 degrees? I have a DBE set with 0 deg offset, but there are times I really could use the clearance.....
- 15° hinged ratchet ring wrenches: ring offset to clear fingers or obstacles.
- Compact ratchet mechanism and reversible by lever.
- Increment 5° (7.5° for dimension 6 mm; 6° for dimensions 7, 8 and 9 mm).
- Ring head angled at 15°.
- Metric sizes: 6 to 24 mm.
- Presentation: satin chrome finish.
I think so yes. They make their own ratcheting mechanism and forge their own wrench body.IS the Snap-On top level?
I second that. Facom are impeccable. Regarding the backdrag they are normal. Lifetime warranty and excellent design. They are not rebuildable but they won't need it. Regarding the Snap ons, the box end is imho huge. The thickness between the stem and the ratcheting end is too much, it hinders the swing. I don't have them thoughI chose the FACOM due to the compact box end, the finish and the comfort in hand. I have had them for a few years now and love them.
I think that USAG, MAC and Porto, maybe even Craftsmen look identical to the FACOM.
I think facom goes up to 41mm.not sure if SAE wrenches are availableWho makes ratcheting wrenches bigger than 1" and 24mm? At work I use a lot of 15/16", 1 1/8", and 1 1/4", 24mm, and 27mm stuff, a 36mm would be really nice for 1 particular job we do. I have a 2 year old set of non reversible standard gear wrenches to 1 1/8" and an O'Riley set of metrics that skips a lot of sizes. I haven't broken one yet though the internet claims they are garbage. My wrenches get filled with slurry and usually a good wd40 bath gets them functioning again. Being able to take them apart and clean them would be really nice.
Thats relatively fresh for a zombie thread here at least. Sometimes it's interesting to see how the replies shift over the years or even decades on these.One year old thread
Love my snap-on reversible ratcheting sets. No issues with them.
I also have Wurth branded non-reversible, flexible ratcheting wrenches. I like them too.
For true, Adam. I've been wrenching for sixty-three years now and don't own the modern ratcheting box ends. How did we git 'er done all those years?I think I just don’t love ratchet wrenches. They can be convenient. These would be the last tools I add to my automotive box.
