Agree with this:
Care to expand on this though?
I've seen it said before but it doesn't make much sense to me. Why isn't a rod end mounted in double shear or single shear with a safety washer OK on the street?
Because rod ends aren't shielded. It doesn't take very much debris getting into the ball to create a notch, which can cause the rod end to catastrophically fail.
Rod ends are designed for race cars and aircraft, where they live a mostly coddled life that's free of salt and grime and rocks and dirt, and they get checked and replaced very often. On a street car you're not checking and replacing the rod ends every few hours.
The counter argument to this would be that there's a zillion people using rod ends on street cars of all types- from HD off road rigs to track cars and everything in between- without a lot of failures. There's also a zillion manufacturers of aftermarket parts that use them for suspension and steering components of all types. That's the truth, but it doesn't change the fact that an unshielded rod end is highly susceptible to damage from dirt and other contaminants, and that minor rod end damage can lead to a major problem if they are used in safety critical areas, like steering.
cliff notes: use rod-ends on a street car at your own discretion. The guys who sell and make them usually will tell you not to.
I do think my material welding question was answered. Now I am just defending my out of the box ideas
I do have both LHT and RHT
Once you connect the drag link mount to the tie rod it limits the adjustability to a 180 degree turn of the heim joints on each end. I have to keep my drag link connection in a very small area to clear everything else that is there.
If the drag link and tie rod each have a RHT rod end on one end and a LHT rod end on the other, you don't have to do any flipping of rod ends. Loosen the jam nuts, turn the drag link (or tie rod) and it will get longer or shorter and toe will be adjusted accordingly. That's the whole point of using left hand thread on one end only.
