Rationalizing the purchase of a backhoe
ArtisanFarms
Phelps, NY
I have a small backhoe that I mount on a compact Kubota and over the years between me and my kids it has been have used a fair amount. It is limited in terms of how deep it can dig, power and changeover time to install the subframe and partially dismantle the 3pt hitch. I'm starting to look at a larger dedicated machine and comparing it to renting a mini excavator when I need one or hiring someone. Renting a mini excavator is better than $300/day in my area once drop-off and pick up are included and hiring someone is $100/hr and up.
In order for hiring someone or renting to really make sense I need to stack up a few jobs to put enough time on the machine to justify the charge, unlike with owning where I can use for 1/2 hour or 5 hours whenever I need it. I can definitely make a case for selling the little hoe (but keeping the tractor) and buying a larger one while I'm building my house and shop, but am not sure if I want to sign up for the upkeep that might be associated with the machine if I keep it longer term.
Has anyone regretted their purchase of a backhoe?
Renegade1LI
long island ny
I have 2 NH tractors with hoes, very handy, I would never sell them, they're always there when you need them. If you have the work for an excavator it's one thing, but for occasional use I would just rent, way cheaper in the long run. But for the right price I'd buy one.
ez-duzit
Marina del Rey
If you buy a used machine that is affordable to just keep around, besides routine maintenance, it will likely also require catching up on deferred maintenance. Parts won't be cheap. And some of the work may require a specialist. For a farm, it is easy to rationalize because of regular use. I had a Case 430CK.
Sumboodie
AK
If you already have the tractor with a hoe, I'd be looking for an excavator. I had never used a backhoe and lots of hours on excavators.
Had to use a backhoe for a project and while we got it done, it sucked compared to an excavator. Can't swing very far, have to spin the seat and reset 300 times, etc.
A backhoe isn't going to do much that your tractor can't, unless it's a tiny tractor.
tarmy
Nor Cal
Get a bigger tractor and frame mounted BH…compact tractors just aren’t big enough to have a decent sized BH. When I was in the market for a tractor…the dealer talked me out of a compact based on my description of what I planned to use it for…and I am very glad he did too.AEADA8A2-523C-4BAB-A088-FD8506A0EE09.jpeg
mcbane
California
I have a backhoe attachment for my bobcat that has definitely earned its keep. But for big or complex jobs I typically rent a mini ex. The 360 degree boom rotation and ability to dig alongside a wall make a backhoe seem really primitive.
If I ever buy another machine it will be a mini ex.
Renegade1LI
long island ny
The only problem is if it sits for long periods of time, but if you keep it moving you'll be better off. We have some equipment in the shop that doesn't get used a lot so we exercise them on a regular basis, plus keep up with all services.
Docswelding
The regret I have is selling it.
larry_g
oregon
I've had a Case 580 for years, one of the most used utility rigs. Great for moving bulk material, grading, digging, lifting. If you want to trench an excavator will be better but if you want to move material then the BH will run circles around it. Have a project down the road? The BH will just drive down to the project, the EX will have to be hauled most times. So think about all the jobs you want your tool to do. I have a BH and my son has both an excavator and a skid steer. Each tool has its strengths and jobs it excels at.
lg
no neat sig line
Prospecter
Maine
I also have a Case 580. Fill up the fluids and check the diesel. Needs a rear tire. Needs hoses. And yes, an excavator probably does the digging jobs better. However, an older industrial tractor with loader and backhoe can be had for little $$$, and generally, things do not all break at once. I keep mine busy, and have no complaints.
Moss
Ontario Canada
I have a 35 horsepower kubota. For a while I had a backhoe for it but I didn't find it all that useful. I use the tractor for other things, lawn cutting, bush hogging etc. So couldn't just leave it on. I started renting mini excavators sized for whatever the task is and for me it's much better. A properly sized mini ex is way better at the actual work. I don't have to maintain it or store it.
Bad Eye Bill
New Brunswick Canada
I bought this old lizard for 1000 bucks a few years ago. It hadn't ran in the previous 10 years or more. Got it running and working, did my digging and was planning on selling it but held off putting it up for sale and then realized it was just too handy to have around so I never did advertise it.
Ugly as hell, lots of looseness, etc. but it has found its home as long as I'm around I guess.
CraigStu
Blacksburg, Va
I have rented a mini-ex twice now. Love running them. Ck w/ your rental places for an over the weekend deal. Mine delivers at 430 or so Friday (so the guy can go home at the standard 5P). They pickup 800 or so Monday morning. It is a screaming deal. Try to figure what you would do w/ it first. The mini has a lot going for it but the little blade most of them has doesn't do much. It will spread dirt around some but you need a backhoe w/ a bucket if you want to move dirt in any quantity.
cannuck
Rural SK
I was fortunate enough to secure a long term loan of a UH-025 compact excavator. Did not want to go down the backhoe route specifically because it limits trench depth and swing amount. Buiilt a thumb for it and now the ultimate rock picker that my 11 YO grandson can run like a champ. I forgot to mention: stability of the tracked machine another big plus.
CDPLUCKER
lynchburg va
bought a kubota B21 to build my house and shop. it was like $12,000 or so at the time, figureing that i would sell at the end of the project and just use my BX with a loader after that. however, i cant see myself ever selling it. it is a really good size, i can tow it with my car trailer, drive it down the road, best all around tool for doing projects ! the great thing is it loader, backhoe and a 3 point tractor in one machine.. sure is you can afford 2 machines a mini excavator and a skid steer are better for moving dirt, but that is two machines you have to buy and maintain. it is all about what and how you are using it, and how much money you have !
Jackfre
N CA
You don’t have to “rationalize” a BH purchase. One of the greatest benefits of having a BH is community relations. None of my neighbors like me, but I have a backhoe and do their digging;), so all good in the neighborhood. Mine is a BX23. I‘ve dug in spots where the clay is so heavy that the 23 couldn’t touch it. Had to rent a mini-ex for that job. Your rationalization will come in picking the size of machine.
Ton ton
Page County,VA
Is that a 202 Massey Ferguson?
RoninB4
Under My House
Need to match the equipment to the soil content. Bought an older 30 hp tractor with a FEL and a backhoe attachment. Tried using the BH on a soil clearing project. The ground around here is loaded with small rocks, clay, and chirt-like fill with a little dirt mixed in. I tried using the BH for 2 sessions of 2 hours each and might as well been using a tea spoon. Sure it was less strenuous than using a shovel but I sure didn't feel the earth move under my feet. I might just have a crew come in next time, a few hundred and the job is done a lot faster than I could do it. Do I regret the purchase? Nope, it lifts heavy things and moves them that I can't.
zkdiesel
chicagoland cornfields
I mean who doesn’t love a good hoe or two. Backhoe gets the most hours for generally versatility, but also travel speed in field is very important in our tiling operation. A mini would need a truck and tilt 63E7C750-0F42-4F0C-86DC-BD01F0060BC0.jpegD864415A-1702-4649-8DA1-B03634A6D028.jpegtrailer to move it around the property
NikonRon
Get an excavator. Bought a Kubota KX121 4 years ago for a project and it's still here. No way I could get by without it around. Very useful around our 13 acres.
Sumboodie
AK
Same. Something around 10-20 tons size.
Looks like the excavator has summer teeth... sum are there, sum are missing :ROFLMAO:
