zeeker
Okay, My first post ever! I love this forum. I hate shaking paint cans, especially new ones. Looking over my piles of junk one day I thought I'd try to build something that would shake for me. The kids left a long time ago! Total cost was zero. I started with a broke down leaf blower and tore it down to the bare bones. I pitched everything that wasn't necessary. I then pulled the jug and removed the rod and piston and drilled and tapped a hole right in the middle. I used a 3/8 24 long bolt cause that's what I had on hand. Pushed the piston back in the hole and marked the top for another hole for the bolt. Blew the chips out and put it back together. (NO NEED FOR GASKETS) I found a sliver of angle iron and a muffler pipe reducer, cut the head off the bolt and drilled a hole in the angle. A spot of weld on the bolt and clamp and the fab is done. I cut most of the threads off the bolt, added some locktite and screwed it in tight. I had this OLD variable speed drill motor taking up space so that's what I use for power. Crank the drill on slow, clamp in the can, lock the trigger, open a beer and sit down. You can watch it go up and down if you really don't have anything else to do. A squirt of oil down the hole every now and then and it should last as long as the drill motor.
