rattle_snake's random shop projects v0.1
PhantomEB
Medicine Hat, AB, Canuckistan
Dude….I need to win the small 2M lotto up here just to be on your level. All I can do is pay bills until the shutdown at the plant hits…..I am one of those guys let it go the full 7 weeks. I can even go 9 or longer dependent on if I sent to Vancouver for a delegate meeting.
R
rattle_snake
Chandler, AZ
Looking forward to seeing the next stage of the truck build Justin. :3gears:
I think it is called 'in pieces'.
Trying to decide where to stop on the front end. Would like to make nice looking inner fenders and a custom core support. Incurs a lot of other small changes. Radiator, battery mount, wiring, hood hinges, etc. Probably bad timing. Should section the fenders with it assembled.
Waffled on how to start off phase 2 of the build. Decided to skip the lift and working underside. Instead leave the truck on the ground and start with removing the front clip. Had to cut up the radiator support to get the AC condenser out with lines intact.
The engine doesn't have to come out, it is a lot of work to do so, but might be easier with it gone. But before it comes out have to measure where it sits, or make some type of temporary support to hold it in place when the cross member is cut out.
R
rattle_snake
Chandler, AZ
Tried to save the translucent finish on the guitar project. I mixed the die to strong and it left marks, but even beside that the color was dark and dull. No life. Tried sanding the color off, but it seemed to burn and get worse. Tried wiping it off with solvent, and that worked well except where I had tried to sand. Sanded through some of the sealer. Banged up the neck reworking it 3 times. So not going to be perfect. Put some more sealer on the sand thru areas and decided to try a different color.
Not sure what the wood is exactly, but it has a red hue to it. I realize I'm not going to get a pure blue color from it. The opposite direction is to add yellow (to green instead of purple), so I dumped some unmeasured amount into the leftover blue/black I had already. Die went to full green. Decided to go for it, put a green coat on front and back. Wow, now it pops. The front sealer was partially sanded through all over, and took the die differently. Put a coat of clear over the die on the front. Needed more color to hide the prior mistakes, so used the straight blue. Better, did another clear on the front only. Then finally a 2nd straight blue. This yielded a dark green, looks to me like an apple Jolly Rancher candy. So sour apple it is, but at least it has depth and a soul. The hardware is gold, and this dark green should go well with it. Bought some gloss polycrylic spray and put down a heavy topcoat. Sanded, another layer, then removed the binding mask and put one final coat of clear on the whole thing.
In the sun you can see the blue topcoats over a green at the bottom. Next step is glue the neck on.
R
rattle_snake
Chandler, AZ
Didn't learn from the last build to be patient with the process. I did manage to let the finish sit for 2 days before rushing final assembly. Maybe the neck should have been glued in first, I don't know, but clamping soft acrylic isn't the best idea. I used some sheets of Teflon to protect the finish from the C-clamps. And while the glue was drying, final assembly as that is the most fun part.
Finish on the back isn't perfect, can still see some of the initial problems.
Headstock is just black spray paint in between water based acrylic.
Figured I should wait a day for the glue to fully cure before putting the strings on and tensioning the neck
The water based polycrylic spray cans are mixed thick, and will not lay flat. Lots of orange peel. At least at 80* and minimal humidity. No amount of sanding will fix the next coat. Dries to touch in 15-20 min. Would have to thin manually and use HPLV gun to get it better.
Next step is to string it, and do a basic setup of bridge and action. Then start to tune and tweak things into a finished product.
R
rattle_snake
Chandler, AZ
Kids are asking to go water skiing so time to get the boat out. Been many years since I have inspected the trailer, last job was replace everything. Axles, brakes, hubs, bearings, seals all new. So add one more project to the queue.
I try to do preventative maintenance instead of roadside repair. At least it fits in the lift bay to avoid working outside in the brutal heat.
One of the four wheels had a leaking rear seal, so going to do all the seals. The grease was grey instead of blue, so it got hot or water in it. The tires still look OK. Gave them a spin slightly off the ground to check for out-of-round, and a thorough visual inspection. Oldest tire is from 2017 so they are pretty much at my age limit.
ntsqd
Lower left coast
Thoughts on "Bearing Buddies"? One of my trailers came to me with them installed. The only deep water that trailer should ever see is stream crossings. I've read that they can push the seal out completely.
R
rattle_snake
Chandler, AZ
The trailer came with bearing buddies, but I wouldn't buy them. I use them more like a regular cap.
If you pump them up enough to compress the spring, it will push the grease out the rear seal, into the brakes.
So I try to run them at the zero/lowest pressure without air pockets. I fill the hub cavity with grease and do my best to get most of the air out. Fill the bearing buddy with grease. Then install the cap. The diagram should be bottomed out. Add grease Just enough to move the diaphragm off the stop a tiny bit. Drive cycle, check again.
R
rattle_snake
Chandler, AZ
I had added a rubber 'bumper pad' under the forward axle shackle to mitigate the loud BANG! every time the brakes are applied. It fell off. Maybe there is a better solution.
The problem is that the equalizer pivot between the shackles get a torque applied when the trailer brakes engage. Then it slams the forward axle's rear spring eye up into the frame, hard. Adding brakes to the forward axle made it worse, force from both springs combined. The frame is being damaged.
How necessary is the equalizer pivot in a dual axle config?
Another option is to lower the equalizer by extending the mount, such that when full pivoted the spring can't contact the frame. The shackle would contact the mount in a parallel fashion. The tires have very little clearance to the fenders as is, so a slight height addition is OK.
Or another way to limit the equalizer travel?
WoodsTruck
I'm shopping for an equalizer linkage setup for my work trailer right now. You should be able to buy a taller equalizer to push the spring mounts a bit lower, or use shorter links.
The equalizer, at least the way I see it, keeps the weight split onto both axles when a wheel rides up over a bump instead of the "high" tire/axle taking all the weight until it settles back down. Also helps with a high or low tongue mount so all weight is shared on both axles.
My trailer has thousands of miles on logging roads and is egging out the holes so the links pound on the frame. Time for some new parts.
WoodsTruck
I was surfing around needatrailerpart.com for the equalizer parts. Decent supply for different dimensions of parts. Some kits, some individual pieces.
M.Brane
1 hr N/W of LA LA Land
I see you did the gold hardware thing. Not usually a fan of that, but it looks good here!
Hopefully it plays nice.
R
rattle_snake
Chandler, AZ
The left handed no-name V kit I bought was only available with gold hardware. Wouldn't have chosen that but lefty stuff is limited. My engineering brain tends to pick plain and repetitive things. Green and gold is not one of them.
I got the guitar strung, basic tune, but forgot to ground the bridge. :confused:
Had a lot of noise and feedback. The pickguard is the access to the electronics, however it was half under the bridge. So had to remove the bridge and modify the pickguard to be removable on it's own. The pickguard also limited how low the bridge could be set, and I was at that limit. So it needed to be done anyhow.
There was a pre-drilled hole for a wire into one of the bridge posts. Posts aren't coming out without likely damage so I did a hack and made a spring loaded contact pin to contact the bridge post. Seems to work OK as far as conductivity.
Retuned but still have noise issues and lots of feedback. If I turn the tone knob to cut out the high frequencies the issues mostly go away. This is with very high gain settings, however the other three 6-strings play just fine (all are passive).
The bridge is grounded and when strings touched the noise is attenuated as expected. I double checked to polarity of the output jack. The pickups are humbuckers already. Not sure where to go from here, moved on to the next project and will have to circle back to resolve.
The V shape is not as comfortable to play sittings down, but it looks so damn cool....
R
rattle_snake
Chandler, AZ
Stringing a guitar is a fun job. Watched some pieces of some videos for some guidance, and there are little handled cranks for the tune pegs as they have to be turned a lot of rotations. Decided to make a powered version with a drill and a PVC fitting. Works great, especially the 2nd time I had to tension all the strings.
R
rattle_snake
Chandler, AZ
Boat trailer axle seals arrived and I was able to re-grease and install all of them. Messy job, grease gun ran out on last pump. All the brakes look good so ready for service.
Pondered what to do exactly with the equalizer pivot and mount. Decided to take one side off and inspect as step #1.
Ok some slight wear. Perhaps explains the noises. Egged out hole allows the shackle to sit higher.
So the sleeve failed and put all the load on the material edge to saw through the bolt. Fantastic.
I see that I can buy equalizers for cheap, under $40. Cast with plastic bushing. Looks like garbage that won't last. The other option are $300 gimmicks. Bumpers, cushions and such sold to old people who don't know any better. The RV parts world is all about taking advantage of elderly with money. But nothing in the middle. Just want a quality part with robust bushings. Don't exist.
Trying to get out to the lake this weekend, so time is a factor. The springs and equalizer are 1.75" wide so making something new is more difficult than a standard size like 2" sq tube. So try to reuse the existing piece. Poly bushed sleeves would be ideal, but not in time and would be $150+ for six of them. I found some 9/16 x 1" DOM I had on hand. Fits bolts perfectly, and should work OK if they stay lubed.
I press out the thin sleeves and bushing and hogged the holes out to 1". Pressed in the new DOM sleeves. Going to weld them in and drill for a grease zerk.
For the center pin, I am hesitant to raise it up too high. I could just weld the bushing on top and be done. However this changes the dynamics of the system. In general things like this like to be stable, in tension. The shackles are in tension, and self align with gravity. The equalizer is not, it is under compression and will flip/flop one way or the other unless balanced by something else. So ideally the equalizer should be upside down, with center pin at the bottom not the top.
It is possible for a dual axle equalizer to go past center and flip one shackle, because the system is not inherently stable. You can buy an equalizer flip kit that spaces down the center pin mount and puts pivot in tension. But the packaging ***** and it hangs down low, more expensive. Mount is long and un-supported. But it solves those issues.
The angle of the shackle on a leaf spring effects the spring rate. The shackle will either push or pull on the spring length wise which makes it deflect. The equalizer is similar, if it was flat it would have no effect on the system. The taller it is under compression, to more unstable it becomes, and moves both shackle pins fore and aft in relation to the mount. Elongating one leaf and shortening the other, effectively lower spring rate of one and increasing the other.
So plan is to put the center pin slightly higher but not significantly. Weld up the old holes. Put it back together.
R
rattle_snake
Chandler, AZ
Spent some time trying to remove the pulley from the power steering pump on the F100. I bought a new pump, with a new reservoir and pulley, AN fittings and so on. The cast pulley material is complete **** and broke immediately as you have to move the pulley to tighten the output fitting. Or remove the reservoir completely. I was able to find an older pulley of same brand, that is made of decent metal. But first to remove the old. Had to slow cut away a 1/4 of the hub and then try to pry it off. Ended up smashing the bearing dust seal a bit. Probably OK will see what happens. I would guess the front bearing is the last piece to come out of the housing.
M.Brane
The white Gibson V in the above pic has EMG 89s. It was my main guitar for a couple decades. Very versatile pickups, and zero noise. Just gotta change out the battery when they start coughing. I actually broke the neck off it once, and discovered it had an air bubble in the joint. Played/sounded better after I re-glued it.
R
rattle_snake
Chandler, AZ
89 is an interesting setup. Didn't realize there is a whole world for modifying electric guitars. It has been fun to learn about all the different aspects of the hobby. Easy to spend a lot of money.....
What do you think of the solderless/connector based electronics? That type of 0.100 header/connector is very common in electronics. There is also a compatible version in a locking style.
Didn't have any time to debug the guitar noise issue. Not sure it is the pickups, the issue is the same if I use one or the other, so it appears to be downstream of the selection switch. But that is just the tone knob and jack. I designed a preamp for a guitar that I could build, but first understand the issue.
R
rattle_snake
Chandler, AZ
Finished out the trailer equalizer repair/improvements. Moved the center pin up about an inch.
For Mk I I used a piece of material to fill the holes.
I did not fully weld the sleeves, but the heat still distorted them such that the bolts no longer fit well. After drilling and tapping for a grease zerk I ran a 9/16 drill through them for a proper clearance.
The reason the shackles were hitting the frame was due to the equalizer center hole being egged out, and everything sitting lower. With that resolved shouldn't make noise or contact.
The spare tire is dated 2011, so it is time to replace it even though it 'looks ok'.
M.Brane
I rebuilt that V back in the early '90s before the solderless stuff was introduced. Don't see any complaints about them. If I ever do another with EMGs I'll go that route. Makes swaps so much easier.
R
rattle_snake
Chandler, AZ
Almost required with the extreme temps, as I get old(er). Was still 100 at 9pm last night. So very lucky to have a climate controlled shop big enough for the trailers.
Replace the spare tire. It looked OK but was from 2011 and that is well past my threshold. Bought a D/8 ply as the C/6s are right at the weight limit empty.
Boat was ready for sea water impeller job. Required every other year regardless of hours or it breaks up into chunks that clog cooling system. Managed to break the plastic housing trying to get impeller into cavity. Slipped out of place, broke and cut my thumb pretty good. I almost didn't do the job for fear of breaking something right before the trip. On top of that the housing was new, it is a wear item and the old was done. I had a narrow window to find one locally Saturday morning, however I had a spare that came with the boat that has been in a box for 17 years. So I put that one on with 9 fingers. Getting the pump back in without a left thumb was even more difficult, but I got it done. Takes a different wrench to get each nut.
Boat batteries are from '23 so charged and made sure each could fire engine. Pulled the fuel filter and dumped out contents to see if there was any water, there was none so put the filter back on and cycled pump to purge air. Checked all the fluids. Trailer banging and noises resolved. I put 30+ hours into the boat and trailer to get it to my level of comfort.
Took the boat out to Canyon lake. Kids brought some friends, and we took the two young dogs, so a boat load. First time in a boat for the dogs, they both love to swim and are pretty good about not scratching people. Was really hot, uncomfortably hot even on/in the water. Spent some time on party beach which is at the inlet, water from bottom of dam above is cold and felt good.
My main cover support PVC/conduit deal didn't work so good and needs some rework to stay centered.
I've been putting off a new Bimini top and some upholstery repair. Hope to get that done over the winter. And new tires. Oil change... and so on.
R
rattle_snake
Chandler, AZ
Spent Saturday pulling the motor and front suspension out of the F100. Forgot to plug the speedo hole in trans and made a big mess of trans fluid. I had built an engine cradle for the 460 which works well, so made a quick wooden version for the 351W.
Ready to break down the suspension
Got the suspension and steering out pretty easy. Decided to break it down to make it easier to move around. Hope to be able to sell the beams/arms/shocks/knuckles/brakes/springs/steering/sway bar. Could be used to convert to 5 lug disc brake and power steering
Need to take some measurements of the frame holes so I can make sure they are properly aligned with whatever I'm going to do. Could weld in some bracing, but it seems like it would be in the way to cut things out. Need to decide what to do about the crossmember that links the cab mounts and what was radius arm mounts. Already modified for the poor fitting headers. Not sure if new headers at this time would be a good idea. Maybe just modify the right side to fit better and call it a day.
phred
NC
Justin I know you said you did want a mustang 2 style setup. This I my 66 f100 that is being built for pro-touring. There should be matching holes in the frame rails where you can bolt in a removable crossmember like I did here too keep everything in alignment. I used a piece of 2” 120 wall tube with 7/16” bungs welded in each end.
R
rattle_snake
Chandler, AZ
Working on the noise issues of the Flying V. I believe it is related to the pickups. If I ground the signal chain anywhere the noise goes away, so it is coming from the signal source itself, the pickups. The pickups are humbuckers but I assume they are the cheapest turds, given the $200 price of the whole guitar. Can spend over $200 on just pickups.
None of my other guitars have any shielding in the cavities. I think it is a band-aid/work-around type solution. Trying to make a perfect faraday cage for a pickup isn't possible.
Same electrical fundamentals apply to an electric guitar as anything else. There are two basic type of antennas that couple noise. A loop and a pole. The loop is very low impedance, and the monopole is very high, as it is only connected on one end. Both will always receive electromagnetic radiation. For a loop, the induced signal level is proportional to the loop area, and the magnetic flux though it.
{\displaystyle {\mathcal {E}}=\oint _{\partial \Sigma }\left(\mathbf {E} +\mathbf {v} \times \mathbf {B} \right)\cdot d{\boldsymbol {\ell }}=-{\frac {d\Phi _{B}}{dt}},}
For a monopole it is more complicated.
I have some aluminum foil 'duct' tape, however the adhesive electrical conductivity is unknown. So for $7 I bought some copper foil tape with conductive adhesive that I can easily solder to.
Removed the stings, pickups and pots to be able to line the cavities with foil. I was also able to use a M8 bolt and a prybar to remove the lower bridge pin to ground it properly.
The existing ground wiring from the manufacturer is distributed. All parts are connected with wires, but at different places. The pickups are grounded to the pots, which are grounded to the switch, which is grounded to the tone pot, that is connected to the bridge and jack. The pickup wires are coax, and have essentially no loop area. Shielded. Beyond that loops everywhere.
Lined the cavities with the foil tape. It's thin and tears in the corners, so have to stick small pieces over the holes. Also did the back side of the pick guard over the cavity area.
Each cavity of foil must be grounded to do anything, otherwise it is still an antenna. Soldered wires to each of them, except for the pick guard as it is already grounded by the bodies of all the pots and the switch.
I decided to do a 'star' or single ground point style of wiring. Reduce the loops. Everything to one location, that is 'ground'. Ideally this would be the jack ground terminal, as that is the reference for the amplifier at high gain, but not physically possible. So inside the pot cavity. There are nine wires in the one node. Three foil cavities, bridge, three pots, switch and jack.
There are still loops in the system, shielded coax would be better than the normal signal wiring (red). But ground only one end of the shield, the receiver side, otherwise you make another loop. So the switch inputs, tone pot input, and jack.
So, how does it perform? Better but not great. More noise than any of the others. Still need to attenuate the high frequencies with the tone knob to prevent feedback. But can play it at full power, so that is a win.
Why does it squeal at high frequencies? All electrical systems have some capacitance/inductance/resistance and make a resonator. The reactive components increase with frequency. For whatever reason this guitar has a peak in the band of frequencies it can produce, which isn't good. But for now it is at least useable. Maybe try the shielded wiring.
ntsqd
Lower left coast
The EE's and their Tech at my previous employer spent a fair amount of time twisting the wires used in our various production machines with a cordless drill motor. Would that help in this situation? Could also use safety wire pliers to do the twisting. Back in my days on APT's dyno the EE semi-frequently borrowed them to twist short runs of d/a wire.
R
rattle_snake
Chandler, AZ
Twisting a pair of wires basically makes the induced EMI the same on both, and is cancelled out when received in a differential fashion. Twisted pair can still benefit from shielding.
It can also ensure a more consistence impedance of the conductors to one another and impedance to the environment. This reduces reflections at high frequencies and improves signal to noise ratio. CAT5/6 wiring is an example.
and it hold the wires together in a bundle physically, which can be helpful instead of loom or tape or straps.
Would it help the guitar? Yes in theory, how much is subjective. Maybe for longer lengths. A passive pickup guitar is not differential, it is single ended and susceptible to noise. XLR (microphone) connectors are shielded differential, and are used in long lengths on stages for signals to the amps.
R
rattle_snake
Chandler, AZ
I found some SMA coax in the recycle bin, 50 ohm. Small at about 1/8" diameter vs the old TV stuff. Might try just the jack wire as that is the longest one.
ntsqd
Lower left coast
M.Brane
EMGs are pretty much the standard for high gain due to their noise rejection. My Mesa MKIII blue stripe will actually produce feedback with nothing plugged in if you crank the gain to max. I usually run it in the 5-7 range depending on which guitar I'm using. Then there's the Townsend approach where you use an SG with P90s into a dimed Hiwatt. Glorious tone/feel, but bring your earplugs.
R
rattle_snake
Chandler, AZ
Squish this to turn it into a tube that lines the holes in the body? Then solder it foil to foil. That changes how you grounded things, and may not be ideal.
I'm posting the thoughts that come to mind hoping to learn more about EMI/RFI shielding and/or avoidance. Not that I have a clue about how to actually do this sort of thing....
Yes you do that to get closer to a perfect cage. The other issue is the pickups themselves, they are a floating design with a plastic ring which would be difficult shield the gaps. Some pickups are in a solid enclosure (soap bar?).
https://mojotone.com/collections/humbucker-pickups
My best friend's brother works for Mojotone. They make some awesome quality stuff.
I run Saturday Night Specials from Seymour Duncan in my hot-rodded Ibanez, more rock/blues/70s countryish...but definitely sound amazing. Probably wouldn't be ideal for anything metal, but they do play AC/DC and ZZ Top well 🤷‍♂️
Wow they both have a very wide range of products. So much cool stuff.
Interesting. So much history of equipment and artists. endless rabbit holes...
R
rattle_snake
Chandler, AZ
Decided to try the shielded coax SM (Sub Miniature) cable on the signal lines. I grounded only the receiver/destination end of the shield.
The pickup to pot wires are already a coax, with the shield used for the signal return, which is also ground. I left it that way. At this point there has to be a circuit, a loop to generate a current from the pickup coil. Some pickup shields are isolated from the signal wires. Not this one.
I was surprised by the reduction of noise. The guitar is completely quiet. Touching the strings no longer has an effect. Touching the strings conducts/shorts out the noise signal into your body which is ground-like. But now the noise level is not audible even under very high gain.
The feedback issue remains, which I don't fully understand. It is a resonance, but could be mechanical or electrical or some combination of both. Have to look into that further. But it makes noises and puts a smile on my face.
