OutlawDrifter
Glad the exhaust is now ear approved. Hanger solution looks good.
I may have to look into that muffler, give them a try on a project.
What tools did you use to press the Polaris ball joints? A buddy called me the other day asking if I could help him with his and I said we could probably improvise some tools, but it would be nice to know up front.
Got one of the Polaris front axle CV done and realized the other boot from amazon was a return of a used one. Wrong part, torn and greasy. Dooh! Replacement coming. Silicon lube delayed. How it goes, not in a hurry.
Ordered a new cover and motor/pump for hot tub. I bent the armature/pump shaft on last rebuild getting seized bearing off so replacing whole unit. So much broken stuff, but I'm too cheap and stubborn to pay someone else.
Rattle_snake you did a great job on that truck and I have really enjoyed following along and appreciating the attention to detail. I hope to someday rebuild a Bronco for my wife and I am sure I will be referencing this thread for inspiration and guidance. Please keep sharing your projects because we all love seeing the updates!
Ya I hope so. the 390/2wd chassis got 9. I can see why it had 3 gas tanks.
I'm avoiding Jerry cans, so went with 32 gal tank to start with. Could have done a 40 but would have been a lot more work to clear axle.
Exhaust is good, happy with it.
It's a nice bike, comfortable, but just not 'me'. In comparison, my 1900 Raider is a brutal beast of power, which is how I like it....
They weren't too bad usually and I was able to make decent money at them but every once in a while I'd get one that simply fought me the entire way coming apart.Making progress on quad suspension job. Got front end done. New bushings. Used press to install new ball joints. (Ryan here is the method...)
Nice job on those CV shafts Justin. I've rebuilt one or two of them back in my powersports days.They weren't too bad usually and I was able to make decent money at them but every once in a while I'd get one that simply fought me the entire way coming apart.
Haha, thanks! It appears there's some specialty tools involved in that press operation! It was actually my buddy that witnessed the wreck that needs the work done.
I had to check mysyelf for grease just looking at all of those CV's! I swear CV grease is just black antiseize.
That thing has such a menacing stance and appearance Justin.
Looks completely bad ***, even for a Ford.![]()
Thanks Mike. We all know you have a soft spot in you heart for Fords!
5170 empty. 5520 with me and full tank.
Add front driveshaft and rear bumper, 5300, empty.
Add spare 40 tire, winch, passenger and tools, about 6k.
I think 4wd parts and big tires added about 800 lbs to what it was.
My 2014 F250 is 8300 empty. 3000 lbs heavier!
My JKUR is 6040 pounds empty full tank of fuel without anyone in it
That bumper just belongs on a 1972 Ford Justin.
My wife's grandfather was a bit **** about his vehicles. When I met him in 1989 just prior to my wife and I getting married I was told the two of us would get along well as my wife described her grandfather as somewhat particular about things.
At the time he had a 1972 Ford F-250 two-wheel drive camper special. It was equipped with the 390 cid/C6 with 2-barrrel FOMOCO carb and it ran very well. In the spring time he would put his Dinocruiser 10.5' camper on the truck and at that time he would install his 12-ply 16.5 tires mounted on split rim wheels. Also at this same time he would install his "summer bumper". This was a custom built extended bumper that came out flush with the back of the camper and had a hitch built into it so he could tow his 14' fishing boat.
When he removed the "winter bumper" he would also remove his "winter wheels" which were just stock split rim wheels. At this time he would sand them down and repaint them before wrapping them up in a blanket ready for fall when he would reinstall them. The bumper was exactly like yours. He'd paint it silver and the wheels white then put them in his garage until they were swapped at the next season in which he would do the same to his summer wheels and bumper.
He was a great guy and loved taking care of his vehicles and his yard/home. When he needed something mechanical he would have me work on his vehicles and would come over to stand guard and make sure I was doing it correctly. He passed a couple of years ago at age 92 but he was a great guy and really gave a whole new meaning to OCD.
Justin, nice work on the bumper, very clean execution as usual. What did you use to cut the plate?
Thanks for sharing this story Mike. Interesting to hear someone somewhat particular about things describe someone else with 'a whole new meaning to OCD'. I have a feeling your grandkids may describe you the same at some point.
