or remove it altogether.
worm clamp. Not a long last solution in the rust belt but it will stop the rattle for a year or two.
For your safety and the safety of others I suggest you find a mentor/teacher for mechanical 101. Or go back to playing with *** toys.
How will you drill out the rivet? With the drill you have yet to purchase?
How about a nut and bolt once the rivet is gone?
BrutalCan this cause a fire? If they melt, I will just use some wire next time. But, can I leave them on for now? Or, maybe I should drill out the rivet thing, and put a bolt, the right way. Next time.
Take it off. Make sure that you park on dry leaves in the fall
Bailing wire . . . . . . you know the stuff that holds bales of HAY !!
Seriously, everyone should have a few pieces of bailing wire for emergencies.
I went to the nearest Tractor Supply to get bailing wire and they didn't have any. I asked and they said they did not stock it anymore, only stock bailing twine.
Ended up getting it at the local feed store.
As to the heat shield, if you run out of zip ties, just use a ratchet strap. Preferably one of those ones from HF that feel like plastic.
Coach
Whooooosh!so it can melt and smells like fresh paint everytime you get out of the car? i wouldnt run a ratchet ******** heat. never have, so i dont know what it will do, but common sense tells me it might join itself to the heat shield.
we just need a picture of what you are working on or forget the picture. you should have it fixed by now lol
