Re-furb my grinder?
goaticus
I have had an 8" Ryobi (I know cheap ****...it was a gift) bench grinder I've had for almost a decade. The other day I turned it on and saw some magic smoke out the back. It started not really wanting to start in the correct direction and with a jump start in the correct direction, it didn't really want to spin up to full speed. After some brief dis-assembly, I see some obvious issues. I am guessing this is the "motor-start" capacitor... which is obviously toast.
The motor was still working but was getting quite warm trying to run without this guy. Should I try to pick up another Cap with the same specs, or just toss the damn thing. I need a grinder so I can grind my boogered tig rods back to shape:lol_hitti
G
goaticus
Found one on Prime for similar price. Specs look the same except for 400V max.
G_P
Central CT
As long as the capacitor voltage is the same or higher as the old one it will work.
pattenp
Virginia - USA
Just make sure the cap will fit in the space. Not all caps of that voltage and Uf are the same dimensions.
