In2toys
the place we are in has 3/4 copper to everything. the tub fills FAST. Ditto on the pex crimper.
I'd run 3/4 to the toilet if there is more than 1 person in the house.
I know what size pipes are standard. It is not for the toilet, it is for the shower.The toilet has a bitty supply tube. A place for large lines is a tub for fast fill but showers are now usually low flow. In the pic above standard is like you have it, with 3/4 mains and has been for decades. Recently energy saver fixtures have drastically reduced demands, a toilet now takes 1.6 over the same time frame it used to take 5 gpm. In my place cannot feel the flush during a shower. You can run the cold 3/4 in the pic above and 1/2 on the hot, makes for faster to the sink.
Kinda funny to see everyone recommend 3/4 in feeds but dont take into account the supply cutoffs. Look at the inside of these and most are <1/4 in. You can only fill so fast no matter how big the line is.
All of my rentals are redone in Pex the first time they have plumbing issues.
My plumber runs 1in to the house and the cold water manifold. 3/4 to the WH and back to the HW manifold. everything else gets 1/2in. Every application runs direct to the manifold.
Why wouldn't you just use full port ball valves?
http://www.supplyhouse.com/Watts-0555110-LFFBVS-3C-1-2-Full-Port-Sweat-Ball-Valve-Lead-Free
How many supply valves are full flow. get real guys.Yeah, those look real good sticking out of the wall.How many supply valves are full flow. get real guys.
Ahh, ok i wasn't thinking when i made that post that you were referring to the shutoffs at the appliance end for some reason. .. Yeah, that wouldn't look all that greatYeah, those look real good sticking out of the wall.How many supply valves are full flow. get real guys.
It reduces the pressure loss at the shower when someone flushes. That is why I asked if there was only one person.
Some of thisWait Time for Hot Water
A significant benefit of PEX piping systems is the opportunity to reduce water and energy
waste by reducing the amount of time to deliver hot water to the outlet from the water heater.
Though hard to quantify definitely, there are indications that hundreds of gallons of water per
year are wasted while waiting for hot water to reach the outlet.
Tests were also performed on each of the three PEX system designs to compare the time it
takes for hot water to be delivered to the test fixture (TF). Figure 8.6 shows the results of delivering hot water to the shower fixture after the pipes were flushed with cold (city) water. The results were normalized to keep the flow rates and temperature from the hot water tank
constant for all systems.
