This is just so you do not make the same mistake that I almost did. I just had my furnace installed today. Well i had basically decided on just running it off of a switch and not using a thermostat. Basically i would just switch it on when I needed it. Well, the reason that is not a good idea is that the blower fan needs to run after it shuts down in order to take the heat off of the heat exchangers, if not it could result in a cracked heat exchanger...
This may be common knowledge, but I just wanted to pass it along.
