And every 4.5' thereafter. Out of picture and OK at 3' at the blocking.NEC 334.30 (for NM cable) states that cable shall be supported within 12 inches of every outlet box, junction box, cabinet, or fitting.
Yes.What does that in blue mean?
So I need to add a block of wood and staple each wire to it within 12" of the panel?
I would have installed that panel with the main breaker on the bottom.
*And please no one use the word upside-down.
Only a 60 amp feeder on 6 gauge THWN between main and sub, then a 100 amp main breaker (disconnect) in the sub. I have LOTS of convenience outlets.
6 AWG is rated for 37 amps for power transmission. I expect the inspector will fail it for that, a 60 amp circuit needs 4 AWG.
And service entrance conductors(what I think youre calling power transmission) are sized on a different table AND they have higher ampacity ratings than branch circuit ratings! But a feeder to a garage IS NOT a service entrance conductor!The subpanel passed a year ago but with only a few circuits. It is a 4 wire feed from the main panel in the house. 60 amp breaker at the main panel. Same as the 60 amp breaker that feeds my hot tub with 6 gauge.
Not sure about the "power transmission" difference but the regular chart says 6 guage NM is good for 55 but you can round up to 60 so that's what I did and the inspector allowed it.
The white wire is there but is hard to see since it is so small. The more circuits I add, the smaller that the 6 gauge looks!
Hu
U didnt use Romex for your feeder, u used THWN so im not sure why u brought up Romex. Anyhow, yes, #6 Romex does have an ampacity of 55a(60c deg column). THWN has a 65a ampacity because it would be sized on the 75c deg column! So i wouldnt worry about the feeder!
Correct.
What is that green screw doing there. Have you installed that bonding screw making this service equipment? In other words, have you mistakenly bonded the equipment grounding buss to the neutral buss?
Correct.
Well, yes, I did. What you can't see is that between the subpanel and the main panel I have a junction box at the house in the house garage where I used to have a welder plug fed by 6/3 romex. At that junction box I switched to conduit and thwn for the outside part of the run. So I treated the whole run as romex nm with the lower 60 amp limit. All inspected of course.
