cubicle
The HF automotive trim tools. $4 and have paid for themselves many times over.
Set of mastergrip ratcheting combo wrenches from Costco for 14 bucks. They won't break.
Ratcheting ball drivers. I seem to collect them.
I'll even buy used ones that don't work, and take then apart and fix them and epoxy them back together for use. I've yet to actually wear one out.
I don't have that exact same one, but typically that sort of thing would run on two AA nicads, though it could also be sub-c's. If you can open it up then you could easily solder in a couple of replacement batteries.
A little tip with devices like that thing, ones that don't have proper "cut-out" chargers, is to buy a small timer (electronic or mechanical) and always set a time limit for the charge. After having several similar experiences of cooking power tool batteries I always use them for charging stuff now days...
Lemme guess: taiwan.
I wonder what factory they came from...![]()
I spent a lot of money trying to find a better-made alternative to the long reach, very-narrow needle-nose pliers I've had as long as I can remember. So far, I haven't been able to match them.
This little utility bar is killer for $2. Yes, it's made in China but for $2 I really don't care. I bought one after watching Stuey's video here:
I have since gone back and bought 3 more of them. I don't know if this is a Christmas only item so if you want one you better go to Lowe's and snag one!![]()
That is copied from a beekeeper's "hive tool." They are made from spring steel and only have the nail puller hole, but are much better for scraping and prying. They usually cost <$10.![]()
Except for the spring, those look like one of these: http://atdtools.com/814I spent a lot of money trying to find a better-made alternative to the long reach, very-narrow needle-nose pliers I've had as long as I can remember. So far, I haven't been able to match them.
I don't have it anymore but when they were closing them out I bought a bunch or the Skil Power Wrenches for $15 each. I gave them all away except one. Used to use it all the time but I left it on the charger for about a month without using it and fried the battery, doh.![]()
All the ones I gave away are still going strong.
Did you look into finding a battery?
This little thing is amazingThat's easy - my Mastercraft bit ratchet set, regularly goes on sale for about $10 at Canadian Tire. I'm sure you folks elsewhere in the world can find something similar. It's amazing how often it has been useful. It might not be high end - I like the Wera set I was subsequently given - but this cheap kit is among the most useful and best value tools I have ever purchased.
http://www.theskrapr.com/the-skrapr-hd/ $10 at Canadian Tire
plastic felling wedge
handy as hell; i use it to open doors up to unlock cars
i used it to support an engine while the transmission was out
i used it to split a flywheel from a torque converter
used it to split engines from transmissions
occasionally even on trees
Does seem handy, but is it strong, can you drive it in, or is it more like a spacer?
Is it a lot better than a piece of wood?
BTW box of scrap wood 2x4, 2x6, 2x8, 4x4. Very cheap, very handy.
they are made to drive into wedge cuts in trees with a sledge hammer. They are pretty damn tough
i like it better than a piece of wood because it doesnt deform or splinter with damage
i too have a pile of scrap 2x and 4x blocks around the shop
