Really Large Radius Gages, Anyone Make Any?
dr_clyde
Holland, MI
I do a lot of reverse engineering. People bring me a broken thing, ask me to make a new one.
Most recently, I had a need to measure what turned out to be a 4.75" radius. There was lots of measuring and math for something that isn't all that critical, where a quick comparison gage would work great.
Seems like most pre-made radius gage sets stop at 1/2", and a few cheap sets go to 1".
I know of the one Baleigh makes that looks like a crossbow. I'm not interested. I want to be able to measure more than 1 direction. Plus, Baleigh can't make a tool worth owning to save their life.
I'm getting close to just making my own, but before I spend all the time and energy, does anyone know of a store bought set? I'd be interested in a set up to 5" radius or so.
If I do end up making my own, what graduations would be useful? I can't see doing every 64th, that would get expensive fast.
Maybe every 1/8" or even 1/4" would probably get me in the ballpark.
I'm drawing a model in solidworks that I should be able to just input different numbers and get a set out of.
Its pretty simple laser work, but I'd still prefer to just buy something.
Alexander
Hudson Valley, New York
From my limited experience and research your best bet for an inside radius might be the Baleigh (or similar looking other branded) options.
Outside radius, I'm still no expert but beyond the other baleigh would you be able to use the old fashioned type of calipers, plus a little math if you know the angle measured?
Assuming if you could get halfway around you'd use regular calipers or a micrometer or something.
Alexander
I know it's not ideal, but if I were in a similar situation on a rare basis, I would probably just print out a few radii full scale on a per project basis. (regular printer or maybe 3d if I'm feeling fancy)
Then again, this doesn't come up often enough in my line of work to make it worth purchasing something. I also have enough round reference items around for comparison that I could get close enough for what I need, so obviously your needs may be different.
D
dr_clyde
Holland, MI
I've been printing stuff off to use for the last few years, and I've decided I want a dedicated tool set for this.
Plus, paper is hard to keep straight and square, and I'm thinking just some laser cut radii will work for what I need.
But if someone makes a nice set I'd be willing to pay a few hundred bucks and save myself the hassle.
PCustoms
VT
Empty cereal box, an old school compass and a good pair of scissors.
Start of the "wrong" side of what you think it is and walk yourself in, should be able to get it dead on in a couple iterations.
LXCam
I don't know of anyone that makes them. But a super sized set like this would be really handy to have around. Even if it were in 1/8" increments up to 3" then maybe 1/4" up to six.
D
dr_clyde
Holland, MI
That's basically what I'm after.
ducksface
If you make them, I'm good for a set in metal, and I'll buy the layout file.
I'll PayPal.
That will offset the cost of your time.
davewo
USA
I made these many years ago. I needed to measure axle tubes and forgings in order to make weld-on brackets. Sometimes measuring with a tape or caliper is not possible. They're graduated in 1/8ths and there's enough arc length to determine if a side fits small, big or just right.
View media item 85025
MShaw
York, Pa.
Why not just hold a square against the radius. Measure from the beam to the tangent point and you have the radius. With a good eye it could be used for an inside radius also.
D
dr_clyde
Holland, MI
I like these, I may make a set like this as well.
D
dr_clyde
Holland, MI
This is basically what I do now. I just want something fast and easy. Which isn't to say measuring with square isn't fast, I just like the ease of use of regular radius gages and they just aren't big enough.
larry_g
oregon
Above is a neat tool that does it all for you. However if you use a caliper and know the length of the jaw to the beam you can get the cord length and the height (jaw length) by having the caliper touch at three places, the ends of the jaws and the beam. If the radius is to big then touch the jaws to the part and measure from the beam to the part and derive the height. Good for outside radius.
Like said by Davewo, won't work in all situations but it will in a lot. Davewo's set is to the nearest 1/8 and from there he can get what he needs. The method used depends on the required accuracy of the part. A lot of difference between the radius needed on a log for a log cabin and the part the machinist has to produce with tolerances measured in arc seconds.
lg
no neat sig line
D
dr_clyde
Holland, MI
I should clarify. I don't plan to use these for precision applications. I use things like this for stuff like tank corner radii and reverse engineering weldments. Just something fast and easy to get me in the ballpark.
For precise machine work, I usually use calipers and gage pins to measure chords and stuff like that.
dontlifttoshift
Beach Park, IL
They have another one with different sizes. 40 bucks for the pair.
https://www.trick-tools.com/Radius_Check_Gauge_TTRCG_366
dontlifttoshift
Beach Park, IL
I have a set, it measures radii. It does so with all the accuracy that I think the OP requested.
jimreed2160
Tallahassee FL
A mid sized radius set exists now in your pantry. The cans are great for woodworking. I just grab a can with the size I need and use it to trace. If you save tomato paste, tuna and coke cans you can build a nice set in no time.
tarbellb
Oregon
These are great! Gave me a idea, if you are going to make your own, perhaps a more compact and less prone to losing one style like this-
(super quick mockup for illustrative purposes)
